Differences between amateur and professional wiring? |
Tdskip |
Jan 3 2020, 07:12 PM
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of). What else comes to mind? |
Costa05 |
Jan 3 2020, 09:43 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
If you are a bit detail obsessed like me, I found that brake cleaner, hard nylon brush, then a soapy water can clean up a tired existing harness pretty well. Rewrap it with new cloth tape from HD.
Also I would add new fuse terminal block to the four main high amp feed wires (10 ga. red) coming off your battery terminal block. I think the stock setup is a bit under designed in my opinion (mine was) Cheap easy insurance. |
barefoot |
Jan 4 2020, 07:29 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
If you are a bit detail obsessed like me, I found that brake cleaner, hard nylon brush, then a soapy water can clean up a tired existing harness pretty well. Rewrap it with new cloth tape from HD. Also I would add new fuse terminal block to the four main high amp feed wires (10 ga. red) coming off your battery terminal block. I think the stock setup is a bit under designed in my opinion (mine was) Cheap easy insurance. Agree here, I had to install a new to me main harness & was afraid of a short somewhere. here's my new fuze box. |
Lo-Fi Version | Time is now: 4th May 2024 - 11:45 PM |
