Differences between amateur and professional wiring? |
Tdskip |
Jan 3 2020, 07:12 PM
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of). What else comes to mind? |
bandjoey |
Jan 3 2020, 08:00 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
http://www.visioneng.com/wp-content/upload...rol.15SEP16.pdf
I learned a lot from this site. I'm kinda an advanced amateur. ....Soldering should not be used in an automotive strand wire application. Why Not? |
ClayPerrine |
Jan 4 2020, 06:46 PM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
http://www.visioneng.com/wp-content/upload...rol.15SEP16.pdf I learned a lot from this site. I'm kinda an advanced amateur. ....Soldering should not be used in an automotive strand wire application. Why Not? I completely disagree with the comment about not soldering the wires. That is an old wives tale. If you take a close look at a factory 914 harness, you will find that every connection on it is soldered. When I rebuilt the DME harness for the 4.0L motor, every connection on it was soldered when I disassembled it. If you do it right, soldering the connections is a very good, reliable connection. |
porschetub |
Jan 4 2020, 07:57 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
http://www.visioneng.com/wp-content/upload...rol.15SEP16.pdf I learned a lot from this site. I'm kinda an advanced amateur. ....Soldering should not be used in an automotive strand wire application. Why Not? I completely disagree with the comment about not soldering the wires. That is an old wives tale. If you take a close look at a factory 914 harness, you will find that every connection on it is soldered. When I rebuilt the DME harness for the 4.0L motor, every connection on it was soldered when I disassembled it. If you do it right, soldering the connections is a very good, reliable connection. (IMG:style_emoticons/default/agree.gif) never had an issue with soldering once I got good @ it (IMG:style_emoticons/default/biggrin.gif). |
Lo-Fi Version | Time is now: 4th May 2024 - 07:29 PM |
