Differences between amateur and professional wiring? |
Tdskip |
Jan 3 2020, 07:12 PM
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of). What else comes to mind? |
IronHillRestorations |
Jan 9 2020, 11:53 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I use black PVC jacketing on my engine harnesses, and I crimp and solder the terminals on both ends (PRN), taking explicit care just to solder the terminal ends. I also use some dual wall heat shrink, and very limited PVC tape
Pretty much all of my engine harnesses are made to spec using factory wire coding, with a couple exceptions due to wire availability. Using too small of a gauge wire is trouble, and too heavy of a gauge will make the wire bundle larger with can be a problem |
Lo-Fi Version | Time is now: 4th May 2024 - 06:47 PM |
