Proper Torque for Seat Belt Bolts |
silver six |
Jul 17 2003, 02:04 PM
Member Group: Members Posts: 203 Joined: 3-February 03 From: San Bruno, California Member No.: 227 |
What does the factory say is the proper torque for seat belts bots in the stationary seat belts for a 1970?
Douglas |
Jul 17 2003, 03:02 PM
QUOTE(silver six @ Jul 17 2003, 01:04 PM) What does the factory say is the proper torque for seat belts bots in the stationary seat belts for a 1970? from the haynes manual... "After tight comes loose" (IMG:style_emoticons/default/laugh.gif) sorry, couldn't resist |
Qarl |
Jul 17 2003, 03:07 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
387 ft-lbs.
Qarl |
Jul 17 2003, 03:08 PM
Just kidding.
I think just moderately tight is enough. Whatever you feel comforatable with your socket or box wrench. Make sure you configure your washers and nylon spacers correctly to allow the seatbelt holsters and belts to rotate freely. |
silver six |
Jul 17 2003, 04:42 PM
Thanks Andy and Karl (insert sarcasm here). Karl, I'll try to get that 387 ft/lb with a 6 foot cheater bar. If I take the targa top off, I should be able to get enough torque on it. I'll let you know if I have any trouble. (IMG:style_emoticons/default/smile.gif)
[Given that no one is really sure what the torque is, and given that these are 17mm bolts, I'm going to guess 30-33 ft/lb. Make sense?]. Thanks for all your help (or unhelp as the case may be). Douglas |
Aaron Cox |
Jul 17 2003, 04:43 PM
i used a .5 inch breaker bar and socket and just wound until it was tight! dont screw around with seatbelts! (IMG:style_emoticons/default/rolling.gif)
Lawrence |
Jul 18 2003, 06:26 AM
If you feel the inside of the longitudinal go "crunch" when you torque it down - it's too tight (or it's rusty as hell in there).
Lo-Fi Version | Time is now: 16th May 2024 - 09:38 PM |
