914 from Florida to Belgium |
KSCarrera |
Feb 25 2020, 08:16 AM
Member Group: Members Posts: 307 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.dailymail.co.uk-22846-1582640243.1.jpg)
You'll be fine... |
dax1969 |
Feb 25 2020, 09:21 AM
Member Group: Members Posts: 360 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
You'll be fine... Ofcourse. Yr pic is the MSC chitra which capesized years ago near Mumbai (IMG:style_emoticons/default/biggrin.gif) |
Big Len |
Feb 25 2020, 03:35 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
dax1969 |
Mar 9 2020, 02:48 AM
She made it !!
Arrival of the trailer First glimpse...pfuw it's the right one There she is... driver said I could unload myself Welcome in rainy Belgium Started working on the car to get her ready for technical inspection. First cleaning done, installed euro lenses and euro turnsignals and put H4s on. Car has good bones but a few things are needed. The brakelights stays on (sticky pedal ? switch ?), no backup lights and no horn. mudhornets ?? bye for now Dax |
DRPHIL914 |
Mar 9 2020, 08:43 AM
great!!
horn will be the contact under the batwing, small tab for the ground wire to be on, brake light most likely is the switch on pedal cluster under the board, it could be bad switch or it may be the pedal when depressed is not contacting the small lever in the switch that has to be pushed, that’s what mine was. for the back up light check the contacts at the transmission. might just be unplugged. that does look like mud-dauber wasp nest on the back of the light. have fun , post lots of pictures |
dax1969 |
Mar 10 2020, 06:52 AM
great!! horn will be the contact under the batwing, small tab for the ground wire to be on, brake light most likely is the switch on pedal cluster under the board, it could be bad switch or it may be the pedal when depressed is not contacting the small lever in the switch that has to be pushed, that’s what mine was. for the back up light check the contacts at the transmission. might just be unplugged. that does look like mud-dauber wasp nest on the back of the light. have fun , post lots of pictures Thks, searched the platform and found same answers. Will dig into it soon. Just installed an electrical washing pump and the jwest fusebox. Will keep posting (and will keep asking questions (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ) bye for now dax |
Lo-Fi Version | Time is now: 5th May 2024 - 02:08 PM |
