Has anyone ever made a 914/8 clone?, Or am I off my rocker? |
Mikey914 |
Jan 16 2020, 10:09 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have seen a few tribute GT cars that are great, but you all know me. I really love doing the obscure.
I have access to some aircraft cases and was thinking about taking 2 IO540s and adding another bank of pistons to one. Yes machining the cases, welding it all up and same with the crank. Wouldn't be cheap, or easy. But if I could make the motor, I could do the rest. Anyone know what the displacement was ? Or any other specs Attached image(s) |
Mark Henry |
Jan 16 2020, 11:13 AM
Emerson Fittipaldi, flat 8 VW engine.
https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. |
ClayPerrine |
Jan 16 2020, 11:36 AM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Emerson Fittipaldi, flat 8 VW engine. https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. Two 2.2 hot rodded VW Beetle engines in a 1100 lb Beetle chassis. 400+ HP and it had a swing axle suspension and DRUM BRAKES!!!!! And you think I am crazy for building my 4.0L 914. This makes me look like a piker....... |
Lo-Fi Version | Time is now: 14th May 2024 - 01:56 AM |
