Has anyone ever made a 914/8 clone?, Or am I off my rocker? |
Mikey914 |
Jan 16 2020, 10:09 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have seen a few tribute GT cars that are great, but you all know me. I really love doing the obscure.
I have access to some aircraft cases and was thinking about taking 2 IO540s and adding another bank of pistons to one. Yes machining the cases, welding it all up and same with the crank. Wouldn't be cheap, or easy. But if I could make the motor, I could do the rest. Anyone know what the displacement was ? Or any other specs Attached image(s) |
Mark Henry |
Jan 16 2020, 11:13 AM
Emerson Fittipaldi, flat 8 VW engine.
https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. |
rgalla9146 |
Jan 16 2020, 03:57 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Emerson Fittipaldi, flat 8 VW engine. https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. The picture appears to be 2 1/2 engines welded together. That's some special welding. |
Mark Henry |
Jan 16 2020, 04:24 PM
Emerson Fittipaldi, flat 8 VW engine. https://jalopnik.com/emerson-fittipaldis-do...-beetle-5799726 Edit: correction, I was a bit off, this was two engines coupled together. The picture appears to be 2 1/2 engines welded together. That's some special welding. I thought they were welded but that article I posted said they were 2 engines coupled together. Also said it used weber carbs (IDA (IMG:style_emoticons/default/confused24.gif) ) that would have been fun to sync. |
Lo-Fi Version | Time is now: 14th May 2024 - 05:30 AM |
