Has anyone ever made a 914/8 clone?, Or am I off my rocker? |
Mikey914 |
Jan 16 2020, 10:09 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have seen a few tribute GT cars that are great, but you all know me. I really love doing the obscure.
I have access to some aircraft cases and was thinking about taking 2 IO540s and adding another bank of pistons to one. Yes machining the cases, welding it all up and same with the crank. Wouldn't be cheap, or easy. But if I could make the motor, I could do the rest. Anyone know what the displacement was ? Or any other specs Attached image(s) |
mb911 |
Jan 17 2020, 07:58 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Best solution is 2 polo motors coupled.. Any GA lycoming is not a good solution.. Just designed around low rpm high TQ.
Mikey914 |
Jan 18 2020, 10:01 AM
Best solution is 2 polo motors coupled.. Any GA lycoming is not a good solution.. Just designed around low rpm high TQ. What you all are missing is the motor as an aircraft engine is set up for low rpm. While the displacement is large for the pistons. The rpm is a function of crank rod and cam. The case makes no real difference it’s just that. Lubrication would have to be addressed also. But from a cost standpoint the T2 case will be cheaper, probably a better candidate. Still, as Andy said. Unless you make the 8 at least as close as you can to factory, why bother? |
Lo-Fi Version | Time is now: 14th May 2024 - 12:19 PM |
