Quick sanity check / look OK? |
Tdskip |
Jan 17 2020, 10:40 AM
Tdskip |
Jan 18 2020, 02:05 PM
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured.
Thank you for the post however, hopefully someone else can make good use of it. |
Mark Henry |
Jan 18 2020, 03:52 PM
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured. Thank you for the post however, hopefully someone else can make good use of it. So did you get early stock HE's? or SSI's? T1 and 4 any time I've tried a 4-1-2 system it's loud as fuch, on my bus it was so bad I capped one of the tips off. |
Tdskip |
Jan 18 2020, 06:52 PM
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured. Thank you for the post however, hopefully someone else can make good use of it. So did you get early stock HE's? or SSI's? T1 and 4 any time I've tried a 4-1-2 system it's loud as fuch, on my bus it was so bad I capped one of the tips off. Hi Mark - going with a stock ‘75 set up for now. Just need to get it back on the road so I can push some other projects forward. I’m thinking this car will likely be the one that gets the 3.2l later this year so trying to keep the spend down for now. Thanks for asking! @dr914 @autoatlanta.com - thanks, figured that out when I was test fitting everything on the bench. Got them on, I think anyway, the right way now. Thanks for the eyes on them. |
Lo-Fi Version | Time is now: 9th May 2024 - 07:33 PM |
