Time for a rebuild?, Time for a rebuild |
Wew |
Jan 17 2020, 06:06 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi All,
I love this community. I have used the search function a bazillion times to gather invaluable information to help troubleshoot and DIY's on my 73 2.0 fuel injection. I have been working on the body for years and have it in pretty good shape. The interior as well is almost done. I have gone through the suspension and replaced shocks and tie rods. New vacuum hoses, rebuilt injectors and all new stainless steel fuel lines. I have worked my way around the engine, and still need to put a new CHT on as it reads cool. Any whoo, I did a compression test today and these were my readings. 1. 110 2. 105 3. 100 4. 130 Some big variances there. Spark plugs are all dark. Is it rebuild time? Recommendations on best DIY rebuild sources books, blogs, youtubes, this forum etc. I want to keep it pretty much stock but am interested in putting the european style pistons in the car. Any other recommendations and opinions are much appreciated. Thanks, Gary |
rgalla9146 |
Jan 18 2020, 11:18 AM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Before removing engine
Re-do the comp test on warm engine with throttles wide open. You might be pleasantly surprised. Someone knowledgible enough to measure everything so thoroughly would never install a hydraulic compatable cam. Verify what is in there. Maybe a change of lifters is in order. Maybe there was an in-between owner who committed that sin ?..... without a hydraulic cam ? |
Wew |
Jan 18 2020, 11:46 AM
Before removing engine Re-do the comp test on warm engine with throttles wide open. You might be pleasantly surprised. Someone knowledgible enough to measure everything so thoroughly would never install a hydraulic compatable cam. Verify what is in there. Maybe a change of lifters is in order. Maybe there was an in-between owner who committed that sin ?..... without a hydraulic cam ? Ok. I will re do the compression test with the throttle wide open and report back later today. I am not sure what I am looking for when it comes to determining if there are hydraulic lifters and cams in the car. Any resources or tips on what to look for would be much appreciated. Thanks, Gary |
Lo-Fi Version | Time is now: 20th May 2024 - 09:14 PM |
