Time for a rebuild?, Time for a rebuild |
Wew |
Jan 17 2020, 06:06 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi All,
I love this community. I have used the search function a bazillion times to gather invaluable information to help troubleshoot and DIY's on my 73 2.0 fuel injection. I have been working on the body for years and have it in pretty good shape. The interior as well is almost done. I have gone through the suspension and replaced shocks and tie rods. New vacuum hoses, rebuilt injectors and all new stainless steel fuel lines. I have worked my way around the engine, and still need to put a new CHT on as it reads cool. Any whoo, I did a compression test today and these were my readings. 1. 110 2. 105 3. 100 4. 130 Some big variances there. Spark plugs are all dark. Is it rebuild time? Recommendations on best DIY rebuild sources books, blogs, youtubes, this forum etc. I want to keep it pretty much stock but am interested in putting the european style pistons in the car. Any other recommendations and opinions are much appreciated. Thanks, Gary |
Wew |
Feb 23 2020, 09:36 PM
Up to my elbows in dirty oil, lots of simple green and scrubbing. All the tins have been removed and painted along with other paintable accessories.
The big surprise was that the second valve for cylinder 1 has a substantial piece of metal missing on the cap. I did find a lose chunk pictured but it’s not the whole piece. Needless to say based on this I am not sure if I should crack the case. As suspected the cylinders are 96mm with flat head pistons. I am including small pictures this time in hopes of being able to show what I have found Image of the broken spring cap This piece fell out More debris This lifter came apart and some of the inside fell out when I tilted the motor. Can anyone tell me if these are hydraulic? Attached image(s) |
Lo-Fi Version | Time is now: 21st May 2024 - 01:31 AM |
