Mystery engine is out |
Tdskip |
Jan 17 2020, 07:47 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Tdskip |
Jan 19 2020, 06:11 PM
So the good news is I was able to drive the car around the block and it seems healthy, but it’s not as torquey as that engine that you and Forrest help me with Keith @914Toy
I also found a goodie I did not know I had! The bad news is that my test drive was only in 2nd and 4th gears since I need to adjust the shifter. Before I dive into that could I get eyes on this please? Don’t think this should be much of any of the white plastic showing, should there? |
ClayPerrine |
Jan 21 2020, 01:44 PM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
So the good news is I was able to drive the car around the block and it seems healthy, but it’s not as torquey as that engine that you and Forrest help me with Keith @914Toy I also found a goodie I did not know I had! The bad news is that my test drive was only in 2nd and 4th gears since I need to adjust the shifter. Before I dive into that could I get eyes on this please? Don’t think this should be much of any of the white plastic showing, should there? There are two different connectors for the cup bushings. The one in your picture is for an early 911 or 914, and is used under the shifter. The other one is longer, and is used with the side shift console. You have the wrong one in there. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:10 PM |
