Mystery engine is out |
Jonathan Livesay |
Mar 15 2020, 08:12 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Tdskip |
Mar 15 2020, 08:14 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
davep |
Mar 15 2020, 09:26 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
solid spacers, maybe 911 elephant foot adjusters, not stock springs from the color of them, rockers appear to have multiple shims.
Tdskip |
Mar 15 2020, 09:34 PM
Thanks - there were a ton of shins in there.
Pushrods has RTV on them - not awesome. Once all of the cylinders head bolts are off the head should just pull off, correct? My guess is that it ain’t too uncommon for them to get stuck from heat cycling? |
Krieger |
Mar 15 2020, 11:09 PM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I wonder if those are water cooled Vanagan heads? They don't look welded, but more like opened up to allow air flow in.
VaccaRabite |
Mar 16 2020, 05:53 AM
En Garde! Group: Admin Posts: 13,424 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
T4 Aircraft parts?
Zach |
Tdskip |
Mar 16 2020, 05:56 AM
Good morning gentlemen.
The heads have been trimmed in some areas, will better document once I get the head off. Given that the cylinders are aluminum I am trying to avoid wedging anything between them and the head to lever it off. Any ideas? Thanks! |
Mark Henry |
Mar 16 2020, 06:36 AM
Is this the turbo engine? 5th head stud mod is what some guys did to try and keep the heads sealed.
Tdskip |
Mar 16 2020, 06:41 AM
Mark Henry |
Mar 16 2020, 06:51 AM
Is this the turbo engine? 5th head stud mod is what some guys did to try and keep the heads sealed. Good morning Mark, it is. Am I missing releasing a stud? Let me check again. We are sooooo close to seeing what the heck this thing is! The head has a 5th stud nut inline with the spark plug, about the place a regular head's plug would be. Makes for 10 studs per side instead of the regular 8. I think they are heavily modified and welded stock heads. |
Mark Henry |
Mar 16 2020, 06:54 AM
The cylinders could be very early EMW nickasil.
sixnotfour |
Mar 16 2020, 07:09 AM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
6 stud, this guy ? check behind rocker shaft..
http://markstephenshighperformance.com/ |
Brett W |
Mar 16 2020, 07:52 AM
Wow, Stephens is still in business all these years later? Interesting.
Tdskip |
Mar 16 2020, 07:59 AM
Thanks gentlemen, let me go look again. Have some penetrating oil on the area where the studs pass through the head.
Is there a chance the cylinders are re-usable? |
914werke |
Mar 16 2020, 10:11 AM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Once all of the cylinders head bolts are off the head should just pull off, correct? Dont for get the under cylinder tin that is held by a 4-5mm bolt to the heads. But considering how wacky this build is not sure they are still there. (IMG:style_emoticons/default/confused24.gif) |
914werke |
Mar 16 2020, 10:17 AM
Wow, Stephens is still in business all these years later? Interesting. Id say more like, frightening! (IMG:style_emoticons/default/stromberg.gif) IMO steer clear of these guys they are in a class of Motormiester & GEX! No, he closed his doors of the shop he had in Tahachapi some 20 years ago. I was unaware he started up again, probably because the statute of limitations had elapsed for all the folks trying to sue him. LINK |
Tdskip |
Mar 16 2020, 10:35 AM
Once all of the cylinders head bolts are off the head should just pull off, correct? Dont for get the under cylinder tin that is held by a 4-5mm bolt to the heads. But considering how wacky this build is not sure they are still there. (IMG:style_emoticons/default/confused24.gif) I did not know that, let me make sure there’s nothing under there. I’ve been reluctant to get aggressive on removing it, will keep poking around and not force anything until you guys tell me it’s BFH time. Thanks! |
ClayPerrine |
Mar 16 2020, 11:35 AM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I wanted to follow up on several requests for pictures of the mystery engine after he tin has been removed. Anyone recognize these bits? The numbers on the cylinders are backwards. The right rear cylinder on a 914-4 engine is #3. Do you have a picture of the bottom of the heads? |
Tdskip |
Mar 16 2020, 02:07 PM
I wanted to follow up on several requests for pictures of the mystery engine after he tin has been removed. Anyone recognize these bits? The numbers on the cylinders are backwards. The right rear cylinder on a 914-4 engine is #3. Do you have a picture of the bottom of the heads? I don’t but will get one and post it tonight. Thanks for the response Cue |
Brett W |
Mar 16 2020, 07:15 PM
Wow, Stephens is still in business all these years later? Interesting. Id say more like, frightening! (IMG:style_emoticons/default/stromberg.gif) IMO steer clear of these guys they are in a class of Motormiester & GEX! No, he closed his doors of the shop he had in Tahachapi some 20 years ago. I was unaware he started up again, probably because the statute of limitations had elapsed for all the folks trying to sue him. LINK Stephens did my heads and supplied my pistons and cylinders back in the late 90s. He did what he did, I didn't know a lot better back then, but we straightened the cylinders and cut the bottoms. It worked out in the end, but apparently I got lucky. |
Lo-Fi Version | Time is now: 26th April 2024 - 05:47 AM |
