Mystery engine is out |
Tdskip |
Mar 16 2020, 07:27 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Glad you did!
Tdskip |
Mar 16 2020, 08:05 PM
Is this the bolt @914werke ?
I had to cut the exhaust off, those exhaust manifold bolts weren’t moving. |
914werke |
Mar 16 2020, 08:19 PM
"I got blisters on me fingers" Group: Members Posts: 10,042 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Bingo. unless removed those heads arent coming off
Tdskip |
Mar 16 2020, 09:39 PM
Tdskip |
Mar 16 2020, 10:09 PM
Mark Henry |
Mar 17 2020, 09:11 AM
If the head are really stuck on in the past I made an spark plug adapter and hooked a hydraulic power pack (tractor, wood splitter, car lift, etc) and it popped the head right off.
Did this on a 36hp engine with fairly high value okrasa heads and it worked good, but it's a bit messy if you miss the waste oil bucket. |
Superhawk996 |
Mar 17 2020, 09:37 AM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If the head are really stuck on in the past I made an spark plug adapter and hooked a hydraulic power pack (tractor, wood splitter, car lift, etc) and it popped the head right off. Did this on a 36hp engine with fairly high value okrasa heads and it worked good, but it's a bit messy if you miss the waste oil bucket. Good idea. I like it! Could the same thing be done with air pressure? 100 psi into two 100mm pistons/head chambers is 2400 lbs of force. Each cylinder contributing ~1200 lbs of force. Seems like that would be plenty without the need to resort to hydraulics that would increase the force by an order of magnitude (x10) using 1000psi hydrualic pressure. Would be cleaner w/o risk of dumping oil. (IMG:style_emoticons/default/idea.gif) |
Superhawk996 |
Mar 17 2020, 09:39 AM
Check out the goop Always amazes me. Mo goop = mo better sealing or so the logic goes. (IMG:style_emoticons/default/av-943.gif) |
rbzymek |
Mar 17 2020, 12:55 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
Check out the goop Always amazes me. Mo goop = mo better sealing or so the logic goes. (IMG:style_emoticons/default/av-943.gif) Superhawk, I would not use air pressure because the head and cylinder would launch like a cannon when it let go.....unlike hydraulic fluid. |
Tdskip |
Mar 17 2020, 01:10 PM
Got 3 of the 4 tubes out, they were really stuck in there.
Once the last one is out I can get to the plate that is blocking access to the remaining two bolts. |
Superhawk996 |
Mar 17 2020, 01:31 PM
Superhawk, I would not use air pressure because the head and cylinder would launch like a cannon when it let go.....unlike hydraulic fluid. (IMG:style_emoticons/default/rolleyes.gif) Good point. Love the collective wisdom of the forum! |
sixnotfour |
Mar 17 2020, 01:36 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pauter T1 ? simular fins
Tdskip |
Mar 17 2020, 09:09 PM
Tbrown4x4 |
Mar 18 2020, 05:03 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
@sixnotfour might have it nailed. One of your pictures looks like there is an extra head stud where the Pauter's are.
Mark Henry |
Mar 18 2020, 06:43 AM
Does it have 5 studs or 6 per cylinder?
Tdskip |
Mar 18 2020, 10:44 AM
Tdskip |
Mar 18 2020, 12:54 PM
Tdskip |
Mar 18 2020, 12:56 PM
@914toy - Keith, your seat of the pants feel (as a passenger no less) for how much torque the car had was right.
sixnotfour |
Mar 18 2020, 02:10 PM
Alot of thought/theory/work went into those heads.. (IMG:style_emoticons/default/popcorn[1].gif)
jd74914 |
Mar 18 2020, 03:29 PM
Very interesting...
Surprised they stayed single plug with all of that work and huge bore. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:23 PM |
