Mystery engine is out |
Tdskip |
Mar 18 2020, 05:38 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I don’t have an eye for good versus bad on 914 heads. Could these be reusable or would it be smarter to go with a more standard genuine Porsche to eat her head that’s been ported etc.? My immediate thought is the more standard the better, and if that’s the case then what do I do with these besides turning it into giant paperweights? Thanks for everyone’s eyes on this rather interesting build, hopefully the process of taking it apart to figure out what it is has been fun for other members here. |
Superhawk996 |
Mar 18 2020, 05:40 PM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
That was awesome! Thanks for posting all the photos!
jd74914 |
Mar 19 2020, 01:18 AM
I don’t have an eye for good versus bad on 914 heads. Cadiz be reusable or would it be smarter to go with a more standard genuine Porsche to eat her head that’s been ported etc.? My immediate thought is the more standard the better, and if that’s the case then what do I do with these besides turning it into giant paperweights? Thanks for everyone’s eyes on this rather interesting build, hopefully the process of taking it apart to figure out what it is has been fun for other members here. This is very neat to see! Thanks for posting all of the pictures! Its not really a matter of good vs. bad; these are very unique and made to work as a full engine combo. I would write off rebuilding this thing as a normal motor though. You’d be ahead of the game just working with something stock if standard is your goal. The cost here to change heads you be huge, everything has been made to work with different cylinders and likely there is a bunch more custom on the bottom end (besides the extra studs). It’s interesting to see they still used copper head gaskets. You might think with all of this work you’d see fire rings or something different. I’m getting the distinct impression you just want to make a normal T4 out of this; that’s really be a shame since someone very clearly put hundreds of hours into building this thing. If that’s your goal I’d put it in some classifieds for trade of a more stock engine to build from. (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Mar 19 2020, 04:54 AM
Hard to tell with the grime in the pic, are the cylinders biral or nickasil?
Inside cylinder, hard magnetic pull is biral, but very slight magnetic pull is nikasil. |
Tdskip |
Mar 19 2020, 06:49 AM
This is very neat to see! Thanks for posting all of the pictures! Its not really a matter of good vs. bad; these are very unique and made to work as a full engine combo. I would write off rebuilding this thing as a normal motor though. You’d be ahead of the game just working with something stock if standard is your goal. The cost here to change heads you be huge, everything has been made to work with different cylinders and likely there is a bunch more custom on the bottom end (besides the extra studs). It’s interesting to see they still used copper head gaskets. You might think with all of this work you’d see fire rings or something different. I’m getting the distinct impression you just want to make a normal T4 out of this; that’s really be a shame since someone very clearly put hundreds of hours into building this thing. If that’s your goal I’d put it in some classifieds for trade of a more stock engine to build from. (IMG:style_emoticons/default/smile.gif) Good morning - thanks for the detailed response. I'm not really sure what I am going to do with this - mainly following up on a promise to pull it apart so we can collectively figure out what the heck it is. Think of it as 914 archeology. (IMG:style_emoticons/default/biggrin.gif) To be fully transparent I am also using this to learn about custom engine builds and how it all has to come together. I've been itching to dig into an engine as it's one of the relatively few things I haven't done on the various vintage cars I've had. My question about the heads mainly was oriented around using 2L heads as a starting point for a big bore build - the heads on this were kind of a paint to live with as they had weird spark plug angles and you had to pull the intake manifolds to remove the plugs (which made tune up and compression testing etc a certain amount of brain damage). Good coaching however, and very much appreciated. |
Tdskip |
Mar 19 2020, 06:53 AM
Hard to tell with the grime in the pic, are the cylinders biral or nickasil? Inside cylinder, hard magnetic pull is biral, but very slight magnetic pull is nikasil. Good morning Mark - thanks for the expertise. I got a hard magnetic pull, I tested with one of those dropped bolt magnetic wands and it firmly attached with strong pull. |
Tdskip |
Mar 19 2020, 09:53 AM
Tdskip |
Mar 19 2020, 09:54 AM
Tdskip |
Mar 22 2020, 11:11 AM
Tdskip |
Mar 24 2020, 12:16 PM
Tdskip |
Mar 24 2020, 01:42 PM
Jonathan Livesay |
Mar 24 2020, 03:26 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
mb911 |
Mar 24 2020, 04:43 PM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I so love this setup.. Someday I will build a type 4 turbo 914
Tdskip |
Mar 24 2020, 08:02 PM
Tdskip |
Mar 24 2020, 08:03 PM
mb911 |
Mar 24 2020, 08:16 PM
Things are ok here.. Feeling like I am legend at the moment..
Still think it would be fun to build that engine correctly |
Tdskip |
Mar 24 2020, 08:57 PM
Things are ok here.. Feeling like I am legend at the moment.. Still think it would be fun to build that engine correctly @mb911 - I think I am going to tear it completely apart and then build it as a normally aspirated engine. External cooler oil cooler and sensible build - then plan to do it all over again in 30k? |
barefoot |
Mar 25 2020, 06:32 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Tdskip |
Mar 25 2020, 07:19 AM
@barefoot - thanks for the response and info. I'll put these in the "save" pile then.
Time to start getting into how this thing was set up, started a related thread on Compression ratio Thanks gentlemen. |
Tdskip |
Mar 25 2020, 09:46 AM
Lo-Fi Version | Time is now: 5th May 2024 - 03:50 PM |
