Wipers don’t work |
Wipers don’t work |
malcolm2 |
Jan 18 2020, 10:18 PM
2nd time happening. I move the wiper lever and no movement.
Last time I pulled the steering wheel, unplugged all 3 connectors, re connected and everything worked. I figured the wiper plug came lose, so I added some duct tape. Connector to connector and they wiped. Damn wipers stopped again tonight. What am i missing? |
ClayPerrine |
Jan 24 2020, 11:11 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Maybe you have the switch mis-wired. I know that a lot of the replacement wiper switches have to have the plastic sleeve removed from the wires, and the one from the old switch installed to fit in the column. So maybe you swapped two wires when you did that?
malcolm2 |
Jan 25 2020, 07:20 AM
Maybe you have the switch mis-wired. I know that a lot of the replacement wiper switches have to have the plastic sleeve removed from the wires, and the one from the old switch installed to fit in the column. So maybe you swapped two wires when you did that? I just pulled it out of the box and installed it. No wiring mods. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:21 AM |
