aoor0708 |
Newbie ![]() Group: Members Posts: 6 Joined: 29-November 19 From: Belgium Member No.: 23,684 Region Association: None ![]() |
Have problems with 1972- 1.7 engine. Engine will not start. Question : Does the fuel pump start when switching ignition ON or does pump only work when cranking ?
Thanks for help. Andre |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues.
Edit: clarified that it's when you turn ignition on you should hear fuel pump prime. |
RKramden |
Newbie ![]() Group: Members Posts: 43 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California ![]() |
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues. Edit: clarified that it's when you turn ignition on you should hear fuel pump prime. Beat Navy, sorry this is my first post ever, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet. Pump starts with ignition, Pump runs when Air sensor arm is moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, it starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
BeatNavy |
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues. Edit: clarified that it's when you turn ignition on you should hear fuel pump prime. Beat Navy, sorry this is my first post ever, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet. Pump starts with ignition, Pump runs when Air sensor arm is moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, it starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem. You're all good, posting in the right forum. But I don't know squat about L-Jet (beyond that the air sensor needs to move for fuel pump to run). There are plenty of L-Jet gurus on the board here (e.g., @ClayPerrine ) who will hopefully chime in to offer help. If nobody responds, I'd recommend starting a new thread with L-Jet in the title so that will "draw them in." (IMG:style_emoticons/default/smile.gif) Edit: And (IMG:style_emoticons/default/welcome.png) |
RKramden |
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues. Edit: clarified that it's when you turn ignition on you should hear fuel pump prime. Beat Navy, sorry this is my first post ever, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet. Pump starts with ignition, Pump runs when Air sensor arm is moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, it starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem. You're all good, posting in the right forum. But I don't know squat about L-Jet (beyond that the air sensor needs to move for fuel pump to run). There are plenty of L-Jet gurus on the board here (e.g., @ClayPerrine ) who will hopefully chime in to offer help. If nobody responds, I'd recommend starting a new thread with L-Jet in the title so that will "draw them in." (IMG:style_emoticons/default/smile.gif) Edit: And (IMG:style_emoticons/default/welcome.png) Thanks for the suggestion, I will see if I can start something..... |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues. Edit: clarified that it's when you turn ignition on you should hear fuel pump prime. (IMG:style_emoticons/default/agree.gif) For first start, cycle the ignition off & on maybe ten times to get the fuel pressure up in the engine bay...after that it should hold pressure and not need cycling.... |
aoor0708 |
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues. Edit: clarified that it's when you turn ignition on you should hear fuel pump prime. (IMG:style_emoticons/default/agree.gif) For first start, cycle the ignition off & on maybe ten times to get the fuel pressure up in the engine bay...after that it should hold pressure and not need cycling.... Thanks to everybody for the support. Problem is solved. Loose contact on the fuel pump (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 13th July 2025 - 10:29 AM |
