'74 1.8L LJet/fuel pump, Fuel Pump not staying on |
RKramden |
Jan 20 2020, 02:17 PM
Newbie Group: Members Posts: 41 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
This is my first time starting a topic, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet and fuel pump. The pump starts with the ignition switch, Pump also runs when Air sensor arm is manually moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, the car starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem.
ndfrigi |
Jan 20 2020, 02:35 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
do you mind also sharing pic of your car and engine? try checking also fuel lines below the fuel tank, maybe the rubber kink. you borrow fuel pressure test kit from local store and try checking of fuel flow and pressure. what city are you?
RKramden |
Jan 20 2020, 03:04 PM
do you mind also sharing pic of your car and engine? try checking also fuel lines below the fuel tank, maybe the rubber kink. you borrow fuel pressure test kit from local store and try checking of fuel flow and pressure. what city are you? Too embarrassed to show any pix just yet. Stripped the wiring harness wrap off of the EFI harness looking for shorts, so imagine a pile of rust with a bunch of loose wires on top. Fuel flow seems fine as it will run when I unplug the air sensor. The car currently in intensive care in Long Beach CA. |
Lo-Fi Version | Time is now: 11th May 2024 - 08:06 AM |
