'74 1.8L LJet/fuel pump, Fuel Pump not staying on |
RKramden |
Jan 20 2020, 02:17 PM
Newbie Group: Members Posts: 41 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
This is my first time starting a topic, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet and fuel pump. The pump starts with the ignition switch, Pump also runs when Air sensor arm is manually moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, the car starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem.
RKramden |
Jan 21 2020, 03:11 PM
thanks Clay, I will check all those things tonight. Big hose to Throttle body absolutly has holes. I have temporarily taped it up with a new one on order. I think I have the oil cap seal in the box of other stuff I have previously bought. All other vacuum hoses are new silicone but I will double check routing. What is puzzling me is that when I unplug the Air Flow Sensor, the car starts and stays running.
jcd914 |
Jan 21 2020, 03:28 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
thanks Clay, I will check all those things tonight. Big hose to Throttle body absolutly has holes. I have temporarily taped it up with a new one on order. I think I have the oil cap seal in the box of other stuff I have previously bought. All other vacuum hoses are new silicone but I will double check routing. What is puzzling me is that when I unplug the Air Flow Sensor, the car starts and stays running. There is a switch inside the Air Flow Sensor that until the flap moves the pump won't run. Disconnecting the Air Flow Sensor eliminates this fuel pump switch and the pump runs when the engine cranks over or the ECU sees an ignition pulse. It sound like the flap in the Air Flow Sensor does not move enough while cranking to close and allow the ECU to turn on the fuel pump. Jim |
Lo-Fi Version | Time is now: 11th May 2024 - 05:35 AM |
