'74 1.8L LJet/fuel pump, Fuel Pump not staying on |
RKramden |
Jan 20 2020, 02:17 PM
Newbie Group: Members Posts: 41 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
This is my first time starting a topic, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet and fuel pump. The pump starts with the ignition switch, Pump also runs when Air sensor arm is manually moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, the car starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem.
ClayPerrine |
Jan 27 2020, 08:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Now you know the harness is bad, so I suggest getting a Bowlsby replacement.
Bowlsby Wiring Harnesses That and a new AFM hose should get you closer to running. |
RKramden |
Jan 27 2020, 10:42 AM
Now you know the harness is bad, so I suggest getting a Bowlsby replacement. Bowlsby Wiring Harnesses That and a new AFM hose should get you closer to running. It's on the list! |
Lo-Fi Version | Time is now: 11th May 2024 - 12:30 AM |
