| DanT |
Jul 4 2005, 02:09 AM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Any suggestions/pictures of oil cooler setups/postitions? Anyone using electric fans or 3.2L Carrera type setup in the fender well with small radiator/shroud and fan?
If I buy the track car I am looking at the only mechanical issue that needs to be addressed is an oil cooler. Thanks |
| ArtechnikA |
Jul 4 2005, 06:08 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
not nearly as much room in a 914 fender as a 911; theirs are as wide as a 7" headlight, but ours are only as wide as the turn signal tunnel.
what works in a track car is a front-mounted cooler, with the exhaust air ducted either out over the top through a hole in the trunk lid, under the car a la 914/6GT or 911 RSR, or possibly through inner fenderwell vents like tha V8 guys get hot air away from the radiator. the Carrera cooler is good if you have access to factory parts cheap, or FluiDyne makes excellent coolers if you go aftermarket. (THe Earl's/SerckSpeed or Mocal coolers are widely available and cheaper, but not quite as efficient i don't think...) there are lots of pictures here showing front-mounted coolers, and the GT duct parts are available if you like that "factory-correct" look. fans won't help you at speed - and might actually hurt. fans are for AC cars in traffic; track cars don't really benefit.. |
| davep |
Jul 4 2005, 09:18 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,362 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Rich is correct. At 5 MPH the airspeed will exceed whatever the fan is capable of. Above that the fan is an obstruction to airflow, and you can overspeed the fan bearings.
Perhaps the engine oil cooler can handle the idle conditions while the oil cooler in the nose can handle the high speed conditions. Much like carbs with idle and full throttle circuits. |
| neo914-6 |
Jul 4 2005, 10:06 AM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Dan,
You are welcome to see the setup for a 2.7 on my ex-track car I bought from a local racer. It is mounted in the front with the exit in the floor. lines are run in the drivers side rocker panel. |
Lo-Fi Version | Time is now: 29th April 2026 - 01:06 AM |
