Carb recommendation |
EJP914 |
Jan 24 2020, 01:12 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I have just about given up on trying to make the car more driveable with the single Weber on my'74 1.8. Never could get it right. If you were going to buy new twin carbs, manifolds, etc what would you buy and from who?
Thanks. Ed |
Daryl32 |
Jan 25 2020, 05:11 PM
Member Group: Members Posts: 133 Joined: 14-January 20 From: Southern California Member No.: 23,827 Region Association: Southern California |
No experience with these carbs or your engine.
But have always had carbs on my cars - I am a per injection baby. Anyway years and years ago a well respected carburetor genius, I mean this man really know his stuff, more then once said " Carbs get blamed as being the issue when it is really an ignition or valve timing/adjustment problem." Just to add to what others have mentioned. |
porschetub |
Jan 27 2020, 01:45 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
No experience with these carbs or your engine. But have always had carbs on my cars - I am a per injection baby. Anyway years and years ago a well respected carburetor genius, I mean this man really know his stuff, more then once said " Carbs get blamed as being the issue when it is really an ignition or valve timing/adjustment problem." Just to add to what others have mentioned. Good points,try to tune carbs without full ignition tune up is a waste of time,let alone bad valve clearances and timing issues. If the OP isn't going back to FI the Dellorto's are a great choice as I found them easy to set up I haven't worked with IDF's but have used other Webers such as ICT and DCNFV's in the past. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:30 PM |
