| amfab |
Jan 27 2020, 03:27 PM
Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None
I was at my mechanic's the other day getting some work on my car (the one that is actually assembled and running) and he had a Beck 904-3.6 in the shop with a 915.
It was such a simple mounting system for the tail end of the 915 I was again wondering if anyone was making a simple 914 chassis to 915 tail adaptor. The Bott kit seems great, but costly—same for the Evo. I figured if this works for the Beck—mounted straight onto a square steel tube with a simple shift rod—couldn't I get solid clean shifting out of something similar for a lot less than (some very pretty and well made) alloy tailpiece? -Andrew |
amfab 915 Mount options Jan 27 2020, 03:27 PM
mepstein Do you have any pics from the back? Jan 27 2020, 03:47 PM
amfab
Unfortunatel... Jan 27 2020, 04:02 PM
sixnotfour I have a similar shift set-up ,,its ok Jan 27 2020, 04:02 PM
amfab
There yah... Jan 27 2020, 04:38 PM
burton73 OK, these are pictures of my V8 car as far as the ... Jan 27 2020, 04:56 PM
914forme Easy enough look at what the Subaru swappers do. ... Jan 27 2020, 05:00 PM
Easy enough look at what the Subaru swappers do. ... Jan 27 2020, 07:26 PM
amfab
Easy enough look at what the Subaru swappers do.... Jan 27 2020, 10:05 PM
burton73 No room for center muffler. I have the same muff... Jan 27 2020, 07:17 PM
porschetub What a beast that would be,power to weight must be... Jan 27 2020, 11:38 PM
amfab
What a beast that would be,power to weight must b... Jan 28 2020, 10:11 AM
What a beast that would be,power to weight must ... Jan 29 2020, 08:05 AM
sharper I have this muffler on each side. I can't rem... Jan 28 2020, 07:14 AM
amfab
I have this ordered muffler on each side. I can... Jan 28 2020, 10:14 AM
sharper The bumpers are fiberglass (car is a '75 model... Jan 28 2020, 12:46 PM
maf914
The bumpers are fiberglass (car is a '75 mode... Jan 29 2020, 07:32 AM
sharper
The bumpers are fiberglass (car is a '75 mod... Jan 30 2020, 09:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 03:23 PM |
