915 Mount options, Beck's 904 seems so simple... |
amfab |
Jan 27 2020, 03:27 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I was at my mechanic's the other day getting some work on my car (the one that is actually assembled and running) and he had a Beck 904-3.6 in the shop with a 915.
It was such a simple mounting system for the tail end of the 915 I was again wondering if anyone was making a simple 914 chassis to 915 tail adaptor. The Bott kit seems great, but costly—same for the Evo. I figured if this works for the Beck—mounted straight onto a square steel tube with a simple shift rod—couldn't I get solid clean shifting out of something similar for a lot less than (some very pretty and well made) alloy tailpiece? -Andrew |
mepstein |
Jan 27 2020, 03:47 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Do you have any pics from the back?
sixnotfour |
Jan 27 2020, 04:02 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I have a similar shift set-up ,,its ok
Attached image(s) |
amfab |
Do you have any pics from the back? Unfortunately no, but I should be able to get some in a few months when it is back in the shop. It was a solid rod with a couple of links, Im thinking it looks like a cable system would probably work easily if there is a simple clean mount fo the tail. I know Patrick used to make one. |
amfab |
Jan 27 2020, 04:38 PM
burton73 |
Jan 27 2020, 04:56 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
OK, these are pictures of my V8 car as far as the 930 trans, body mods to make the trans rear support fit the 914 body and the top view of rear trunk to show how I put in the moved back trans support as well as the factory 930 rear trans support mounted to the trans. Stock 930 trans mount on a flipped 930 so it hangs down and is not under the trans.
You can come down to my shop in Inglewood that you have been to see if this is an option for you on a 915 box. I am going to use Cable Shifts set up for linkage. You can use the same with a 915 Best regards, Bob B (IMG:style_emoticons/default/bye1.gif) |
914forme |
Jan 27 2020, 05:00 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Easy enough look at what the Subaru swappers do. And looks like little room for a center mounted muffler? Is that true?
burton73 |
Jan 27 2020, 07:17 PM
No room for center muffler. I have the same muffler that Driveabilty had in his GM V8
car. From Driveabilty You tube-- I installed a set of mufflers which came off a Ferrari 575. The mufflers use a butterfly valve to switch from a quiet sound to a low deep tone when your really hard on the throttle. https://www.youtube.com/watch?v=wlnDze_xVJA Bob B (IMG:style_emoticons/default/wub.gif) Sound |
mepstein |
Jan 27 2020, 07:26 PM
Easy enough look at what the Subaru swappers do. And looks like little room for a center mounted muffler? Is that true? I have the pms trans mount. I just need a shifter. Ben will make me a muffler/s to fit. Attached image(s) |
amfab |
Jan 27 2020, 10:05 PM
Easy enough look at what the Subaru swappers do. And looks like little room for a center mounted muffler? Is that true? I have the pms trans mount. I just need a shifter. Ben will make me a muffler/s to fit. I wonder if Ben would be interested in making a PMS style mount. I don't think they make that one anymore |
porschetub |
Jan 27 2020, 11:38 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
What a beast that would be,power to weight must be off the clock ,great wheels also (IMG:style_emoticons/default/pray.gif) .
sharper |
Jan 28 2020, 07:14 AM
Member Group: Members Posts: 146 Joined: 5-June 03 From: Woodstock, GA Member No.: 789 Region Association: South East States |
I have this muffler on each side. I can't remember if they are from a 993 or 996 (according to the guy I purchased the car from).
Attached thumbnail(s) |
amfab |
Jan 28 2020, 10:11 AM
What a beast that would be,power to weight must be off the clock ,great wheels also (IMG:style_emoticons/default/pray.gif) . Mechanic said that owner has a bit of trouble with it because it breaks the rear wheels in second all the time. I was surprised that the wheels are aluminum. I have no idea where they come from |
amfab |
Jan 28 2020, 10:14 AM
I have this ordered muffler on each side. I can't remember if they are from a 993 or 996 (according to the guy I purchased the car from). I have an extra set of 993 mufflers and tips, that back end looks great. I like the color keyed bumper top too. Im a long way off from having to sort this as I am still fixing rust in the chassis. The 904 just got me thinking about how to mount the 915 |
sharper |
Jan 28 2020, 12:46 PM
The bumpers are fiberglass (car is a '75 model) and the guy I bought it from said the painter got the black and red backwards on accident. But he liked the look on the car and I agree that it looks great. Both front and rear bumpers are like this.
maf914 |
Jan 29 2020, 07:32 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
The bumpers are fiberglass (car is a '75 model) and the guy I bought it from said the painter got the black and red backwards on accident. But he liked the look on the car and I agree that it looks great. Both front and rear bumpers are like this. I agree, it looks good. Could you post a photo or two of the front bumper? Thanks. |
mepstein |
Jan 29 2020, 08:05 AM
What a beast that would be,power to weight must be off the clock ,great wheels also (IMG:style_emoticons/default/pray.gif) . Mechanic said that owner has a bit of trouble with it because it breaks the rear wheels in second all the time. I was surprised that the wheels are aluminum. I have no idea where they come from 904 replica wheels. Not cheap but never made for the torque of a 3.6 |
sharper |
Jan 30 2020, 09:21 AM
The bumpers are fiberglass (car is a '75 model) and the guy I bought it from said the painter got the black and red backwards on accident. But he liked the look on the car and I agree that it looks great. Both front and rear bumpers are like this. I agree, it looks good. Could you post a photo or two of the front bumper? Thanks. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:59 PM |
