915 Mount options, Beck's 904 seems so simple... |
amfab |
Jan 27 2020, 03:27 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I was at my mechanic's the other day getting some work on my car (the one that is actually assembled and running) and he had a Beck 904-3.6 in the shop with a 915.
It was such a simple mounting system for the tail end of the 915 I was again wondering if anyone was making a simple 914 chassis to 915 tail adaptor. The Bott kit seems great, but costly—same for the Evo. I figured if this works for the Beck—mounted straight onto a square steel tube with a simple shift rod—couldn't I get solid clean shifting out of something similar for a lot less than (some very pretty and well made) alloy tailpiece? -Andrew |
mepstein |
Jan 27 2020, 03:47 PM
914-6 GT in waiting Group: Members Posts: 19,280 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Do you have any pics from the back?
amfab |
Jan 27 2020, 04:02 PM
Do you have any pics from the back? Unfortunately no, but I should be able to get some in a few months when it is back in the shop. It was a solid rod with a couple of links, Im thinking it looks like a cable system would probably work easily if there is a simple clean mount fo the tail. I know Patrick used to make one. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:42 PM |
