How many additional quarts of oil do you need?, External oil cooler question. |
Craigers17 |
Jan 29 2020, 05:48 PM
Senior Member Group: Members Posts: 734 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
So this is probably a stupid question, but I'm assuming that if you choose to run an external oil cooler, you have to add at least another quart of oil due to the additional volume in the lines and cooler coils.
I'm also guessing that the additional volume varies depending upon the cooler location. So if a stock 2.0 - 4 takes roughly 3.5-4 quarts, how much additional oil is required? Let's assume a rear mounted unit. Or...is it as simple as fill up the cooler and lines, install, and then fill as normal until it matches the dipstick fill line? Any advice/ridicule is welcome. Thanks. |
SirAndy |
Jan 29 2020, 06:07 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
How many additional quarts of oil do you need?, External oil cooler question. There's no one right answer for that, every install of a remote cooler i have seen has been different. Mine takes about 16 quarts total to fill up nicely. (IMG:style_emoticons/default/unsure.gif) |
Mark Henry |
Jan 29 2020, 07:51 PM
I assuming T4 with a plate cooler, 8AN lines.
Maybe a liter. |
Coondog |
Jan 29 2020, 08:08 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
12 quarts for my 3.2
VaccaRabite |
Jan 29 2020, 08:10 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Yeah mine with a rear mounted aux cooler, lines and a tuna can is about 5 quarts instead of 4 if everything drains out.
But that said, the oil cooler never completely drains so its more like 4.5. Zach |
tomeric914 |
Jan 30 2020, 08:49 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Mine takes about 16 quarts total to fill up nicely. HOLY CRAP Andy! Just how big is your cooler and tank? I have a 12" x 12" Setrab cooler that lays flat up front and a Patrick tank behind me. Anything more than 10-11 quarts in it and it starts filling the burp tank when running hard on the track. So it's more of a try and see thing depending on how you run your car. Andy is running a 3.6 and I'm running a 3.0, both dry sumps. For the OP, I'd fill the engine to the dipstick line, take it for a short drive, park it and let it cool down, then check the level and add oil as needed. |
Steve |
Jan 30 2020, 08:55 AM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
TheCabinetmaker |
Jan 30 2020, 10:27 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Mine takes about 16 quarts total to fill up nicely. HOLY CRAP Andy! Just how big is your cooler and tank? I have a 12" x 12" Setrab cooler that lays flat up front and a Patrick tank behind me. Anything more than 10-11 quarts in it and it starts filling the burp tank when running hard on the track. So it's more of a try and see thing depending on how you run your car. Andy is running a 3.6 and I'm running a 3.0, both dry sumps. For the OP, I'd fill the engine to the dipstick line, take it for a short drive, park it and let it cool down, then check the level and add oil as needed. Andy has a six. |
Craigers17 |
Jan 30 2020, 07:56 PM
Thanks for everyone's input....very interesting. I would have never thought that on big sixes with front coolers, it would take up to 16 quarts. I bought a car that should be in my possession soon, and I'm thinking about relocating the cooler from it's current position up front back to the rear. If I do relocate, I would be going to a smaller cooler with a fan, which was one reason for the question.
There are a few reasons for the relocation, but I want to see it in person before I get to deep in the details. Thanks and I'll post pics when I get the car. (IMG:style_emoticons/default/beerchug.gif) |
brant |
Jan 31 2020, 01:05 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
my front mounted cooler on my Type 4, takes 9quarts total
my twin front mounted coolers on my /6 take 19quarts total (and I do an oil change in this car after every weekend it runs...) |
brant |
Jan 31 2020, 01:06 PM
Thanks for everyone's input....very interesting. I would have never thought that on big sixes with front coolers, it would take up to 16 quarts. I bought a car that should be in my possession soon, and I'm thinking about relocating the cooler from it's current position up front back to the rear. If I do relocate, I would be going to a smaller cooler with a fan, which was one reason for the question. There are a few reasons for the relocation, but I want to see it in person before I get to deep in the details. Thanks and I'll post pics when I get the car. (IMG:style_emoticons/default/beerchug.gif) front coolers ultimately cool better.. so depending on the wear state of the motor and its ability to maintain temp... you will bet better cooling out of a proper front system |
Craigers17 |
Jan 31 2020, 02:44 PM
Thanks for everyone's input....very interesting. I would have never thought that on big sixes with front coolers, it would take up to 16 quarts. I bought a car that should be in my possession soon, and I'm thinking about relocating the cooler from it's current position up front back to the rear. If I do relocate, I would be going to a smaller cooler with a fan, which was one reason for the question. There are a few reasons for the relocation, but I want to see it in person before I get to deep in the details. Thanks and I'll post pics when I get the car. (IMG:style_emoticons/default/beerchug.gif) front coolers ultimately cool better.. so depending on the wear state of the motor and its ability to maintain temp... you will bet better cooling out of a proper front system That's a valid point, and I really didn't want to get too deep in the weeds on this before I have laid eyes on exactly how things are set up with this vehicle. However, I THINK the current owner is using airflow from the holes behind the valence/spoiler area, as it is currently missing the front spoiler. When I replace the front spoiler, I don't think there will be sufficient airflow to feed the cooler. Ideally, I would like to close those holes back. My other option would be to make a proper cutout for the cooler, however there is a better than 50/50 chance that this car is a mostly original Bumblebee LE, so I don't want to cut on it. Much of this is supposition on my part, and I need to see it in order to really view what is going on. I've included a pic of an old car of mine with the area in question that I think he is currently using to provide airflow to the current unit. It's where the 8 or 9 black caps are....imagine if they were removed. |
Cairo94507 |
Jan 31 2020, 03:22 PM
Michael Group: Members Posts: 9,770 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
So, that is exactly what we did on my car. I have the GT style oil cooler in the front trunk and we left the 5 center most black plugs out and have the valance slightly modified to allow more air to flow to those openings. We have a shroud covering the oil cooler and sealing to the trunk floor. The floor is louvered for air to flow out. We should know pretty soon how that works for cooling. (IMG:style_emoticons/default/beerchug.gif)
Craigers17 |
Jan 31 2020, 03:34 PM
So, that is exactly what we did on my car. I have the GT style oil cooler in the front trunk and we left the 5 center most black plugs out and have the valance slightly modified to allow more air to flow to hose openings. We have a shroud covering the oil cooler and sealing to the trunk floor. The floor is louvered for air to flow out. We should know pretty soon how that works for cooling. (IMG:style_emoticons/default/beerchug.gif) That's actually very encouraging info.....especially considering the build quality of your six. I'll take an even closer look at your build thread and get some additional visuals. I appreciate your feedback...by the way, it goes without saying, your car looks fantastic! (IMG:style_emoticons/default/beerchug.gif) |
Cairo94507 |
Jan 31 2020, 03:45 PM
Thank you very much. The credit goes to Kent, Jim, Andy and Bob. They know what they are doing.
Here are a couple pictures showing the front valance: (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:35 PM |
