L-Jetronic/Engine Rebuild, Help with EFI Newbee |
Banham361 |
Jan 31 2020, 08:41 AM
Newbie Group: Members Posts: 2 Joined: 31-October 19 From: UK Member No.: 23,610 Region Association: England |
Hello There
Please be gentle as I am New to air cooled technology but I can be a quick learner. I am about to rebuild my 75 1.8 motor to a 2055cc. My question is: do i have to either change or upgrade the L-Jetronic FI to cope with the increased power/capacity. Many Thanks Tony PS...............HAPPY BREXIT DAY (IMG:style_emoticons/default/piratenanner.gif) |
Tdskip |
Jan 31 2020, 09:07 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Welcome Tony - good to have you with us on the forum.
Short answer - you should be fine as far as FI goes if everything else is healthy. Longer answer - this is a pretty frequent topic of discussion and there is a wealth of material here. Easiest way to find it is to actually use Google to search this site. Try something like this; "914world.com 2056 Ljet" But omit the quotes, you'll find some excellent prior discussions that way. By all means do ask follow-up and clarifying questions. |
Porschef |
Feb 1 2020, 12:00 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Greetings
I too am running a 2056 with an Ljet system. Will file my disclaimer relatively quickly here but I have done some tinkering/adjusting/replacing and have gotten the car to the point where I’m very happy with how it runs. Suffice to say that your engine will run with the factory system. The three items that I’ve found made the most difference are, in no particular order, a wide band AFR meter, a larger throttle body, and a 123 distributor. My only complaint, if I can call it that, is running at initial start up. I’d like to be able to turn the key and experience an elevated idle speed followed by a proper idle. I do need to feather the throttle for about 30 seconds at cold start until it will run by itself. That said, you’ll appreciate the extra oomph provided. (IMG:style_emoticons/default/beerchug.gif) |
Banham361 |
Feb 1 2020, 01:16 PM
Thanks Guys
Porchef..........did you use the standard camshaft. Tony |
Porschef |
Feb 1 2020, 03:57 PM
No
The engine was rebuilt featuring a 9550 cam, Keith Black pistons and AA cylinders. |
Mark Henry |
Feb 1 2020, 04:18 PM
Greetings I too am running a 2056 with an Ljet system.... My only complaint, if I can call it that, is running at initial start up. I’d like to be able to turn the key and experience an elevated idle speed followed by a proper idle. I do need to feather the throttle for about 30 seconds at cold start until it will run by itself. That said, you’ll appreciate the extra oomph provided. (IMG:style_emoticons/default/beerchug.gif) Same here I took a known Ljet system off of my 914 stock 1.8 and put it on a customers 2056, w/#73 cam. Had every part including the dizzy. My 1800 started turn of the key, never had to touch the gas, but now the 2056 cold I had to start the teen like a carbed engine. After that it worked flawlessly. |
ClayPerrine |
Feb 1 2020, 08:42 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Greetings I too am running a 2056 with an Ljet system.... My only complaint, if I can call it that, is running at initial start up. I’d like to be able to turn the key and experience an elevated idle speed followed by a proper idle. I do need to feather the throttle for about 30 seconds at cold start until it will run by itself. That said, you’ll appreciate the extra oomph provided. (IMG:style_emoticons/default/beerchug.gif) Same here I took a known Ljet system off of my 914 stock 1.8 and put it on a customers 2056, w/#73 cam. Had every part including the dizzy. My 1800 started turn of the key, never had to touch the gas, but now the 2056 cold I had to start the teen like a carbed engine. After that it worked flawlessly. That is the same thing that happens on Betty's car. When it had a stock cam, it would start and idle great, even cold. With the Raby 9590 cam, we have to hold the throttle open to get it to start, and it won't idle until it gets some temp into the engine. Once it is warmed up, it runs and idles great! |
Porschef |
Feb 2 2020, 07:14 AM
Ok, so then it’s not just me... glad I’m in good company (IMG:style_emoticons/default/beerchug.gif)
Both descriptions apply. However, the larger throttle body and the 123 helped tremendously. It’s as if the AAR is no longer a factor. (IMG:style_emoticons/default/dry.gif) Makes me wonder if the factory unit won’t allow quite enough unmetered air through on startup. Or maybe I should just be content with things as they are... |
BeatNavy |
Feb 2 2020, 07:45 AM
Not to get this thread TOO far off track, but my 2056 D-Jet with 9950 does same thing when cold. Also glad to hear I'm not the only one. I ended up drilling another small hole in the throttle body plate based on a thread where I saw Jake said "it needs more air!" Didn't seem to help.
jim_hoyland |
Feb 2 2020, 03:29 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Agree : that a 1-2-3 Distributer and larger TB are a big plus. I’m running 96 mm pistons and 2 liter crank; no change to cam.
Starts up fast, idles initially around 1700, then settles in at 90o |
Lo-Fi Version | Time is now: 21st May 2024 - 01:33 PM |
