New GB - Electrical - Ignition and fuel injection harnesses, Complete plug and play injection harnesses labeled! |
Mikey914 |
Feb 5 2020, 01:50 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have been doing these for a while now. We want to bring the cost down, and doing these in quantity will allow for us to to reduce the cost and pass that on. We are looking for 10 of each to get the pricing good for you.
1st The ignition harnesses - We have the replicated all of the parts including the L shaped tube at the transmission reverse light. We have the 70-71 72 73-76 We have these for sale on the site but want to gear up to make in bulk and are offering a price for the GB if we can get 10 takers. These are correct color coded wires and plugs Just +1 Ignition harness and the year we need 10 and can provide these for $210 reg 250 25 and we can make for $199 Attached thumbnail(s) Attached image(s) |
Mikey914 |
Feb 5 2020, 02:15 AM
Now for the Fuel Injection harnesses
These will save you hours of tracking down shorts that are intermittent. We have the 72+ 1.7 L and the 73 20.L harnesses we are just finishing up the early 70-71 harness this week And can do a 1.8 harness if there is an interest we have reproduced all the parts needed to make these even the D grommet at the ECU. As well as the circuit board mount clip. Notice the way we wrap the wires so they will not pull. The only part we didn't reproduce is the "handle" that screws into the bracket on the board, as you shouldn't need to replace them. Ours will accept the old handle. Best of all we label our ends. Is this the #3 or #4? pretty easy to tell. As well as the other ends. We have taken the liberty of creating a common ground for the 3 leads that require it. easy enough to un-clip and go direct if you wish, but we tried to make it as easy as possible. These normally go for $494 each, but if we can get 30 takers we can sell these at $399 each. I'm hoping more as we may be able to reduce further if we get the economy of scale Just need a +1 for the F/I harness with engine and if it's 1.7, early or late. I think you will like these. https://900designs-container.zoeysite.com/1...-wiring-harness Attached image(s) |
Lo-Fi Version | Time is now: 10th May 2024 - 08:23 PM |
