Engine is looking good, anyone care to check it out? |
urbanskater |
Jul 17 2003, 10:26 PM
Newbie Group: Members Posts: 38 Joined: 6-June 03 From: St. Pete, FL Member No.: 795 |
just thought i would post pictures of the engine, its only temporary, one because i will get more crhome on it and stainless gas lines, and two we will build up the engine. so hope you enjoy the pics.
urbanskater |
Jul 17 2003, 10:27 PM
and another one
Qarl |
Jul 17 2003, 10:29 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Very, very, nice! Good job! (IMG:style_emoticons/default/beerchug.gif)
seanery |
Jul 17 2003, 10:36 PM
I'm thinking red sheet metal looks pretty good!
Andyrew |
Jul 17 2003, 10:46 PM
That looks very good! You painted the engine cooling stuff, what did you use for that? and how long will that last? Did you use High temp paint for all that or what..
Andrew |
Brad Roberts |
Jul 17 2003, 11:31 PM
Yeah.. the fan housing turned out NICE. What did you use on it ??
B |
urbanskater |
Jul 17 2003, 11:47 PM
ah hah your talking about the cast aluminum look, yep i used cast aluminum spray paint, from your local walmart store. It'll actuelly last longer on the engine block and what not than the red metal(also sprayed) cause it doesnt scratch as easily. But i'm hoping that after the engine gets started itll bake it but i shall let you know how it turns out if you really wish to know.
Brad Roberts |
Jul 17 2003, 11:53 PM
Only problem with painting everything... it all comes off the first time you need to clean the engine or check for vacuum leaks with brake cleaner or carb fluid.
B |
Andyrew |
Jul 18 2003, 12:06 AM
Ya, but it looks good when you take pics!!! (IMG:style_emoticons/default/tongue.gif)
I might have to try some of that stuff, what was the brand that you used? Thanks Andrew |
seanery |
Jul 18 2003, 06:52 AM
powdercoating is the ticket!
Bleyseng |
Jul 18 2003, 08:12 AM
Amen, I powdercoating all the tin and the fan housing for $150. I dropped off nasty, slightly rusty parts and picked it up 1 week later better than new.
Geoff |
Lo-Fi Version | Time is now: 21st May 2024 - 10:31 PM |
