drem914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,057 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California ![]() ![]() |
I have on of those black plastic covers for the battery.
![]() How are they held on? I am told by a rubber band? Seem a bit odd. |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,850 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
I believe that these covers are for recall to stop water from mixing with the Battery said and that was the quick fix from factory. I have a brand new one for the 75 I just bought and the recall was in the recites with everything Porsche did to the POs car. Rubber band is good for a while to hold it on. I am not going to run it just keep mine for the originality of car
Bob B (IMG:style_emoticons/default/shades.gif) |
UROpartsman |
Member ![]() ![]() Group: Members Posts: 295 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None ![]() ![]() |
This is the first-generation Battery Cover, which was attached with a large black square-profile rubber band (p/n 010 409 549B, still available last we checked). The covers helped prevent rain or wash water from getting inside the open-cell batteries (overfilling resulted in battery acid running into the the hell hole), and are quite desirable for proper restorations of pre-75 cars.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,777 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
So what was the path of the rubber band ?
How did it put tension on the cover. ? Can someone post a pic of how to install ? |
drem914 |
So what was the path of the rubber band ? How did it put tension on the cover. ? Can someone post a pic of how to install ? This is exactly my question. I have it on a currently and is held in place by the ground cable. not enough wind or vibration to shake it loose. ![]() |
michelko |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None ![]() |
Here you can see how it is secured
Michael Attached image(s) ![]() |
rgalla9146 |
drem914 |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,187 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
yes a black rubber bank, round in profile. Believe it or not a factory original part
http://www.autoatlanta.com/Porsche-914-Bat...010409549B.html I have on of those black plastic covers for the battery. ![]() How are they held on? I am told by a rubber band? Seem a bit odd. |
michelko |
The pic is taken from the factory repair manual.
That is a brilliant source for information. Michael |
drem914 |
Sadly, doesn't look like I have any front or back lip on my battery to hold the band on. The lips are on the ends of the battery only. (IMG:style_emoticons/default/sad.gif)
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,973 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The battery cover shown above is the earlier style from the first recall 9J in October 1970. The later HO recall in 1977 featured the later smooth top style battery cover which just snapped on and did not have the rubber band. Of course either is correct for a 914 but if your car was around for the 1977 HO recall that’s the most current version, especially if you have the HO sticker in the front trunk.
Artfrombama |
Member ![]() ![]() Group: Members Posts: 331 Joined: 21-January 24 From: Huntsville, Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
The battery cover shown above is the earlier style from the first recall 9J in October 1970. The later HO recall in 1977 featured the later smooth top style battery cover which just snapped on and did not have the rubber band. Of course either is correct for a 914 but if your car was around for the 1977 HO recall that’s the most current version, especially if you have the HO sticker in the front trunk. @JeffBowlsby @wonkipop 1 211 915 411 c This cover came with my 74 1.8. I don't know if it is original or from something else ![]() ![]() |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
The battery cover shown above is the earlier style from the first recall 9J in October 1970. The later HO recall in 1977 featured the later smooth top style battery cover which just snapped on and did not have the rubber band. Of course either is correct for a 914 but if your car was around for the 1977 HO recall that’s the most current version, especially if you have the HO sticker in the front trunk. @JeffBowlsby @wonkipop 1 211 915 411 c This cover came with my 74 1.8. I don't know if it is original or from something else ![]() ![]() I have one of these, it snaps on. simple. AFAIK it came from George |
JeffBowlsby |
Thats the factory HO recall campaign battery cover. Snaps on, no rubber band needed like the early version.
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,815 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
The battery cover shown above is the earlier style from the first recall 9J in October 1970. The later HO recall in 1977 featured the later smooth top style battery cover which just snapped on and did not have the rubber band. Of course either is correct for a 914 but if your car was around for the 1977 HO recall that’s the most current version, especially if you have the HO sticker in the front trunk. @JeffBowlsby @wonkipop 1 211 915 411 c This cover came with my 74 1.8. I don't know if it is original or from something else ![]() ![]() @Artfrombama @JeffBowlsby would know. here is also one from a very original 1.8 sold recently on BAT. lying around in trunk of car in the photos. same as yours and has the recall sticker on it as well. ![]() my reading of the part number you quote is 211 in it means its a type 2 part i believe. originally was meant for a bus (kombi). the 411 numbers at end are used right through 70s and 80s for various battery covers in various model VWs. im guessing the original battery cover part listed in PET (the smaller one) was superceded with the bus one and the bus one probably got developed a little later than during 914 production run. its a real deal thats for sure. |
wonkipop |
here you go @Artfrombama and @JeffBowlsby
Porsche/Audi were handing out VW bus battery covers in that later recall. looks like this one is either a C same as they handed out for 914s or its a G variant. a bit later. photo not quite legible. ![]() ![]() |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Here’s mine. Original recall cover. A bit hacked to fit ground terminal.
Took me a few days to find it in my stash. ![]() ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 02:19 AM |
