914 2.0 (4-cyl) Piston Rings, A question |
John |
Jul 5 2005, 01:24 AM
Which piston rings should I buy for the MAHLE 914 2.0 "Euro" pistons/cylinders? I was planning on buying the 94mm set from Pelican.
The pistons and cylinders are still ok, but I want to replace the rings while I have it apart. Are the stock piston rings (94mm) compatable with the "Euro" pistons? Any suggestions? |
type47 |
Jul 5 2005, 07:35 AM
piston ring sets are sized to the diameter of the piston, so since the diameter of the US version is 94mm and the euro is also 94mm, they can use the same ring set. now the manufacturer of the ring set you should buy is another story. i just bought a generic set based upon the part number (039.xxx.xxx, whatever the # is...) but hopefully,some experienced person can recommend a brand name for a ring set. the only brand i think you should avoid is TOTAL SEAL as i have read some problems w/typeIV. there are also DEVES but i don't know how they rate relative to other brands.
Cap'n Krusty |
Jul 5 2005, 10:08 AM
You're asking if you should use stock rings on stock pistons? Yes. Avoid the aftermarket rings, especially "total seal", which don't appear to work well in our engines. The Cap'n |
Type 4 Unleashed |
Jul 5 2005, 11:58 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
The dia. on the euro and US spec pistons are 94mm, but I believe the ring thickness ( ring lands ) are a different size. Measure them before ordering, might save you the time & trouble of sending them back, if there the wrong ones. |
Type 4 Unleashed |
Jul 5 2005, 11:49 PM
Which piston rings should I buy for the MAHLE 914 2.0 "Euro" pistons/cylinders? How about MAHLE? |
Lo-Fi Version | Time is now: 21st May 2024 - 12:10 AM |
