John
Jul 5 2005, 01:24 AM
Which piston rings should I buy for the MAHLE 914 2.0 "Euro" pistons/cylinders? I was planning on buying the 94mm set from Pelican.
The pistons and cylinders are still ok, but I want to replace the rings while I have it apart. Are the stock piston rings (94mm) compatable with the "Euro" pistons?
Any suggestions?
type47
Jul 5 2005, 07:35 AM
piston ring sets are sized to the diameter of the piston, so since the diameter of the US version is 94mm and the euro is also 94mm, they can use the same ring set. now the manufacturer of the ring set you should buy is another story. i just bought a generic set based upon the part number (039.xxx.xxx, whatever the # is...) but hopefully,some experienced person can recommend a brand name for a ring set. the only brand i think you should avoid is TOTAL SEAL as i have read some problems w/typeIV. there are also DEVES but i don't know how they rate relative to other brands.
