Getting old(er) added air now fuel injection |
akellym |
Feb 22 2020, 02:28 PM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
So after 2018 the wife and decided that we just didn't want to drive in the heat any more. So last year I install air... It's so nice driving with the windows up and cool! The only issue is the carbs. We have to turn off the AC at stops and stop and go traffic. Now we are looking at fuel injection kits. We are leaning towards a kit from CB Performance: https://www.cbperformance.com/product-p/7075.htm
Here's some photos of the AC. I modified the underdash unit as I did not want to cut my center console. |
Mark Henry |
Feb 23 2020, 12:03 PM
For AC you are better off running a plenum induction system. If your engine is basicly stock with carbs the plenem will be just as powerful and easier to tune. Performance engine will lose some but may be worth it for drivablity and ease of maintenance.
Cb system IIRC is modified GM unit, works but not my favorite. SDS is the simplest system to tune and has an AC fast idle relay. They work good on stockish engines you can run fuel only with a stock ignition and save install time. Con is it costs more and you have to run TPS only for ITB's and healthy cams. MS will also work with your AC, can be cheaper, but con is the tuning is a steeper learning curve. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:04 PM |
