wheel cleaner, tired of scrubbing, and toothbrushes |
porbmw |
Feb 25 2020, 01:03 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
But I don't want to use anything caustic...
Anyone recommend a product that truly cleans.but doesn't etch or otherwise damage..with a simple application, and a hose down??? (IMG:style_emoticons/default/driving.gif) |
Feb 25 2020, 06:15 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I use brake clean
Sprout |
Feb 25 2020, 07:18 AM
Member Group: Members Posts: 125 Joined: 5-October 18 From: Kansas City Member No.: 22,544 Region Association: Upper MidWest |
If they’re just straight up aluminum, I use fine steel wool and Mother’s aluminum polish.
stownsen914 |
Feb 25 2020, 07:43 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Won't steel wool of any kind, scratch the wheels?
I haven't found any magic formula for cleaning wheels - just elbow grease. One tip is to be careful which brake pads you use. Metallic pad material rusts to wheels after it gets wet. Once that happens, I haven't found anything other than abrasives that will get it off. |
rhodyguy |
Feb 25 2020, 08:03 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Try a product that contains Oxalic Acid. 'Bar keepers Friend' is a very gentle abrasive product that has OA in it. Cleans stains on SS cookware like crazy (I use OA crystals in water on my cedar deck prior to the Cabot stain too. Works GREAT!). Do a small test spot. Check YouTube for using OA on aluminum.
infraredcalvin |
Feb 25 2020, 09:21 AM
Distracted Member Group: Members Posts: 1,511 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Waxing your wheels will help, depending porosity and texture. If painted try ceramic coating them. These will help, but have never heard of a no elbow grease solution....
Sprout |
Feb 25 2020, 09:46 AM
Won't steel wool of any kind, scratch the wheels? I haven't found any magic formula for cleaning wheels - just elbow grease. One tip is to be careful which brake pads you use. Metallic pad material rusts to wheels after it gets wet. Once that happens, I haven't found anything other than abrasives that will get it off. Mine cleaned up really nicely, no scratches. I used a slightly heavier gauge steel wool with the polish, then switched to fine (or maybe extra fine) and went over them again with the polish. I still need to clean up the inner black area, but won't use steel wool there! before: after: |
dr914@autoatlanta.com |
Feb 25 2020, 09:51 AM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
nothing just cleans with a spray down, one has to use elbow grease, as there is always a film left. We have had good success with the Sonax wheel cleaner, which softens the brake dust and does not etch alloy wheels, and the a good brush, towel, and yes toothbrush (I always save ALL of my old toothbrushes!!
Like one of the previous comments, for the painted wheels, waxing really helps But I don't want to use anything caustic... Anyone recommend a product that truly cleans.but doesn't etch or otherwise damage..with a simple application, and a hose down??? (IMG:style_emoticons/default/driving.gif) |
76-914 |
Feb 25 2020, 10:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Mothers, cotton rags and elbow grease. Howmuch elbow grease depends upon how often I polish the Fuch'ers. (IMG:style_emoticons/default/lol-2.gif) Twice a year takes about 5-10 mins a wheel. It's easier if I remove the wheels and stack them 2 high to avoid bending over. (IMG:style_emoticons/default/beerchug.gif)
Jamie |
Feb 25 2020, 10:10 AM
Senior Member Group: Members Posts: 1,030 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Rather than steel wool, I recommend the gray ScotchBrite pads available at Lowes. These pads don't rust or stick like splinters in your fingers., I've used them for years in finishing my woodturnings (IMG:style_emoticons/default/piratenanner.gif)
DRPHIL914 |
Feb 25 2020, 10:13 AM
Mothers works well, I would not use a scotch brite pad or steel wool if you are just doing a clean and deoxidize you will scratch the metal and then you are in for a 6 sept process to get those deep scratches out.
StarBear |
Feb 25 2020, 10:14 AM
Senior Member Group: Members Posts: 1,864 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
For basic cleaning, including brake dust/film, P21S Wheel Cleaner has worked for me, especially for the insides. Hadn't thought of light steel wool/Scotch Brite and polish for finishing the outsides; nice tip.
Lo-Fi Version | Time is now: 9th May 2024 - 12:53 AM |
