Checking oil temperatures, Gauge doesn't have scale |
PanelBilly |
Feb 25 2020, 07:03 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'm using a gauge I got from George that fits correctly with a 60mm core, but it doesn't have a scale. I was thinking I'd get a meat thermometer with a long cord and dropping it down the oil tank. If I did it before and after a drive, I could kind of calibrate the gauge My concern is that the tank temperature would be significantly different than the case.
rgalla9146 |
Feb 26 2020, 07:19 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Oil tank ?
Six cylinder temp is measured with a sender threaded into the block near the fan. Gauges with a numbers are available for Porsche instruments, VDO aftermarket and others. Or....do you have a dry sump 4cyl. ? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 PM |
