Oh oh...., Wheel stud issue |
jim_hoyland |
Feb 26 2020, 06:04 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
As I was rotating my wheels, I see one front wheel stud is shorter. I shot pics before putting the wheel on.
IIRC, this stud had some movement several years ago. Not sure how to proceed. The billet hubs are mounted onto the rotors; these are the one Brad Roberts sold awhile back. Calipers show how much thread is showing @Mueller Attached image(s) |
Root_Werks |
Feb 26 2020, 06:07 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Look like threaded studs, double-nut and turn it out. Probably held in place with thread locker.
SirAndy |
Feb 26 2020, 07:03 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Look like threaded studs, double-nut and turn it out. Probably held in place with thread locker. (IMG:style_emoticons/default/agree.gif) Take two out and compare the length, if you are lucky, this one just ended up deeper than the others. Otherwise replace it with a longer one to match the others. (IMG:style_emoticons/default/popcorn[1].gif) |
jim_hoyland |
Feb 26 2020, 07:13 PM
They started out the same length. I noticed this one stud had worked its way down when changing the wheels previously.
Can't remember if the studs are threaded inside and screwed in or had splines and pressed in. Double nuts; I'll pick up tomorrow, what size will I need ? Look like threaded studs, double-nut and turn it out. Probably held in place with thread locker. (IMG:style_emoticons/default/agree.gif) Take two out and compare the length, if you are lucky, this one just ended up deeper than the others. Otherwise replace it with a longer one to match the others. (IMG:style_emoticons/default/popcorn[1].gif) |
Mikey914 |
Feb 26 2020, 07:15 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Safe to say at least one is not threaded. Sorry
bob164 |
Feb 26 2020, 08:42 PM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Jim, you will need M14 1.5 nuts, I think Bay Hardware in Seal Beach has them, if not try Hilco Fasteners in Garden Grove.
Bob |
jim_hoyland |
Feb 26 2020, 09:02 PM
Jim, you will need M14 1.5 nuts, I think Bay Hardware in Seal Beach has them, if not try Hilco Fasteners in Garden Grove. Bob Thanks. Will go over tomorrow (IMG:style_emoticons/default/smile.gif) |
DickSteinkamp |
Feb 26 2020, 09:05 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Generally, threaded wheel studs have a "stop" so that they all go in to the same depth...
If the one was forced in past the stop, the threads in the hub could be damaged. |
Mueller |
Feb 26 2020, 11:09 PM
Brad had a few versions made. The version I drew up only had 4 lugs.
Mine had steel Timecerts with longer BBS racing studs with a non-threaded section like those shown above (BBS studs are all black) If the studs on my design pushed further inboard it would bottom out sooner than your picture shows. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:16 PM |
