74 Roller rebuild and Subaru conversion, 1974 rebuild and Subaru conversion project |
mgarrison |
Feb 29 2020, 09:54 AM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello,
I new around here, but have been lurking for a bit trying to soak up all the 914 knowledge and information I could! I was looking into building a Factory Five 818 kit with the Subaru flat-4, but the cost of entry was a bit too high, and the time & space needed to build a car from scratch seemed overwhelming. But it got me thinking; that's basically a tube-framed 914 with an odd body. I wonder if anyone has put a Subaru flat-4 in a 914? A few Google searches later I learned that a lot of people had, and parts were out there to spend my money on! Long story short, I found two rollers with no engines or transmissions in Tucson, AZ a couple of hours South of me. Soon I rented a car hauler for a couple of days and my "Craft Project" (my wife's label) was begun. The rollers were a green 1971, and a red 1974. I wanted to restore the 71 because it just seemed to have more character. The 74 had been partially stripped for an electric conversion project, and seemed less "car like". Sadly, the 71 needed a bit more work than I was setup to handle. So, it had to be the 74 who I have simply labeled as "Red". I will try to track my build process here as best I can. I tend to get working on things and forget to document things, but will try to keep track. Here's Red when we got her home on the trailer and tucked away in the back yard for the moment. Mike Attached image(s) |
mgarrison |
Apr 2 2020, 03:49 PM
Got the tar off the floor pan fairly easy, but that seam sealer is some tenacious stuff! Floors look really solid.
The worst rust spot and only penetration is behind the drivers seat, on the upper firewall. Seems like an odd spot for rust to collect/happen. I found a couple of odd holes with rather large bolts & washers in them. One in the front middle of where the drivers seat would be. And one behind the drivers seat in the middle as well. Nothing like these on the passenger side. I did find stress cracks on the driver's long at the indent for the hand brake. No rust, just the cracks. Kind of artistic looking in the closeup. I took the wire wheel to the rust hole on the firewall. It opened up quite a bit and I discovered someone had tried to Bondo over it from the engine side. Why, why, why... |
Lo-Fi Version | Time is now: 1st May 2024 - 05:44 PM |
