74 Roller rebuild and Subaru conversion, 1974 rebuild and Subaru conversion project |
mgarrison |
Feb 29 2020, 09:54 AM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello,
I new around here, but have been lurking for a bit trying to soak up all the 914 knowledge and information I could! I was looking into building a Factory Five 818 kit with the Subaru flat-4, but the cost of entry was a bit too high, and the time & space needed to build a car from scratch seemed overwhelming. But it got me thinking; that's basically a tube-framed 914 with an odd body. I wonder if anyone has put a Subaru flat-4 in a 914? A few Google searches later I learned that a lot of people had, and parts were out there to spend my money on! Long story short, I found two rollers with no engines or transmissions in Tucson, AZ a couple of hours South of me. Soon I rented a car hauler for a couple of days and my "Craft Project" (my wife's label) was begun. The rollers were a green 1971, and a red 1974. I wanted to restore the 71 because it just seemed to have more character. The 74 had been partially stripped for an electric conversion project, and seemed less "car like". Sadly, the 71 needed a bit more work than I was setup to handle. So, it had to be the 74 who I have simply labeled as "Red". I will try to track my build process here as best I can. I tend to get working on things and forget to document things, but will try to keep track. Here's Red when we got her home on the trailer and tucked away in the back yard for the moment. Mike Attached image(s) |
914forme |
Jan 16 2021, 09:43 PM
You need a sealer step for the paint and even then bad things can happen and these cracks will reappear.
@MB911 - look above at the welding question about the weld wire difference. To me it looks like you drawing up contaminates from the back side of the weld. But Ben is the expert. |
76-914 |
Jan 16 2021, 09:46 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You need a sealer step for the paint and even then bad things can happen and these cracks will reappear. @MB911 - look above at the welding question about the weld wire difference. To me it looks like you drawing up contaminates from the back side of the weld. But Ben is the expert. (IMG:style_emoticons/default/agree.gif) but why did it change when he changed spools? Is it possible that a spool is contaminated? Maybe not enough shielding gas? Watching for Ben's reply. I do see lots os splatter around those suspect areas! (IMG:style_emoticons/default/popcorn[1].gif) |
mb911 |
Jan 17 2021, 07:26 AM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
You need a sealer step for the paint and even then bad things can happen and these cracks will reappear. @MB911 - look above at the welding question about the weld wire difference. To me it looks like you drawing up contaminates from the back side of the weld. But Ben is the expert. (IMG:style_emoticons/default/agree.gif) but why did it change when he changed spools? Is it possible that a spool is contaminated? Maybe not enough shielding gas? Watching for Ben's reply. I do see lots os splatter around those suspect areas! (IMG:style_emoticons/default/popcorn[1].gif) What number designation wire are you using? Just because it's. 030 doesn't mean its the same wire. It also does look like your drawing in contaminates. |
Lo-Fi Version | Time is now: 1st May 2024 - 06:43 PM |
