74 Roller rebuild and Subaru conversion, 1974 rebuild and Subaru conversion project |
mgarrison |
Feb 29 2020, 09:54 AM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello,
I new around here, but have been lurking for a bit trying to soak up all the 914 knowledge and information I could! I was looking into building a Factory Five 818 kit with the Subaru flat-4, but the cost of entry was a bit too high, and the time & space needed to build a car from scratch seemed overwhelming. But it got me thinking; that's basically a tube-framed 914 with an odd body. I wonder if anyone has put a Subaru flat-4 in a 914? A few Google searches later I learned that a lot of people had, and parts were out there to spend my money on! Long story short, I found two rollers with no engines or transmissions in Tucson, AZ a couple of hours South of me. Soon I rented a car hauler for a couple of days and my "Craft Project" (my wife's label) was begun. The rollers were a green 1971, and a red 1974. I wanted to restore the 71 because it just seemed to have more character. The 74 had been partially stripped for an electric conversion project, and seemed less "car like". Sadly, the 71 needed a bit more work than I was setup to handle. So, it had to be the 74 who I have simply labeled as "Red". I will try to track my build process here as best I can. I tend to get working on things and forget to document things, but will try to keep track. Here's Red when we got her home on the trailer and tucked away in the back yard for the moment. Mike Attached image(s) |
mgarrison |
Jan 17 2021, 09:15 AM
Thanks guys. Its an inexpensive, gasless, DC inverter welder. I got the HF version since its was $75 less than the same thing at HD/Lowes. Don't want to mess with tanks, and I'm working outside. The label is gone from the Lincoln wire, so not sure on the exact details...
Thanks! Mike |
mb911 |
Jan 17 2021, 12:29 PM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Thanks guys. Its an inexpensive, gasless, DC inverter welder. I got the HF version since its was $75 less than the same thing at HD/Lowes. Don't want to mess with tanks, and I'm working outside. The label is gone from the Lincoln wire, so not sure on the exact details... Thanks! Mike There a really over 25 different kinds of Lincoln innershield wire, you may have gotten something that is metal core, composite, or even solid wire. My guess is you got the wrong wire. |
tazz9924 |
Jan 18 2021, 02:09 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Thanks guys. Its an inexpensive, gasless, DC inverter welder. I got the HF version since its was $75 less than the same thing at HD/Lowes. Don't want to mess with tanks, and I'm working outside. The label is gone from the Lincoln wire, so not sure on the exact details... Thanks! Mike There a really over 25 different kinds of Lincoln innershield wire, you may have gotten something that is metal core, composite, or even solid wire. My guess is you got the wrong wire. I agree looks like you have mig wire instead of flux core |
Lo-Fi Version | Time is now: 1st May 2024 - 07:12 PM |
