74 Roller rebuild and Subaru conversion, 1974 rebuild and Subaru conversion project |
mgarrison |
Feb 29 2020, 09:54 AM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello,
I new around here, but have been lurking for a bit trying to soak up all the 914 knowledge and information I could! I was looking into building a Factory Five 818 kit with the Subaru flat-4, but the cost of entry was a bit too high, and the time & space needed to build a car from scratch seemed overwhelming. But it got me thinking; that's basically a tube-framed 914 with an odd body. I wonder if anyone has put a Subaru flat-4 in a 914? A few Google searches later I learned that a lot of people had, and parts were out there to spend my money on! Long story short, I found two rollers with no engines or transmissions in Tucson, AZ a couple of hours South of me. Soon I rented a car hauler for a couple of days and my "Craft Project" (my wife's label) was begun. The rollers were a green 1971, and a red 1974. I wanted to restore the 71 because it just seemed to have more character. The 74 had been partially stripped for an electric conversion project, and seemed less "car like". Sadly, the 71 needed a bit more work than I was setup to handle. So, it had to be the 74 who I have simply labeled as "Red". I will try to track my build process here as best I can. I tend to get working on things and forget to document things, but will try to keep track. Here's Red when we got her home on the trailer and tucked away in the back yard for the moment. Mike Attached image(s) |
mgarrison |
Feb 3 2021, 04:39 PM
More trunk work - that took a lot longer than I anticipated! Safely covered with some primer for now. Need to figure out what/how/where I want to coat it with...Still debating the paintable rubberized uncoating vs. spray bedliner vs. body color. Want to hide my welds/repairs/treated rust and make it look at least decent...
Let's call it finished! Got the center tunnel wire brushed out as best I could. Treated it with rust converter, let it sit overnight, brushed it again, let it sit and then rinsed it out good. Vacuumed it with wet/dry vac, and then took the lawn blower to it to dry everything as much as possible. Added a quick coat of primer after hitting it with a wire brush again to remove any residue from the rust treatment. Waiting on more primer and more internal frame paint to finish up the tunnel and floors... (IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
Lo-Fi Version | Time is now: 1st May 2024 - 10:07 PM |
