74 Roller rebuild and Subaru conversion, 1974 rebuild and Subaru conversion project |
mgarrison |
Feb 29 2020, 09:54 AM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello,
I new around here, but have been lurking for a bit trying to soak up all the 914 knowledge and information I could! I was looking into building a Factory Five 818 kit with the Subaru flat-4, but the cost of entry was a bit too high, and the time & space needed to build a car from scratch seemed overwhelming. But it got me thinking; that's basically a tube-framed 914 with an odd body. I wonder if anyone has put a Subaru flat-4 in a 914? A few Google searches later I learned that a lot of people had, and parts were out there to spend my money on! Long story short, I found two rollers with no engines or transmissions in Tucson, AZ a couple of hours South of me. Soon I rented a car hauler for a couple of days and my "Craft Project" (my wife's label) was begun. The rollers were a green 1971, and a red 1974. I wanted to restore the 71 because it just seemed to have more character. The 74 had been partially stripped for an electric conversion project, and seemed less "car like". Sadly, the 71 needed a bit more work than I was setup to handle. So, it had to be the 74 who I have simply labeled as "Red". I will try to track my build process here as best I can. I tend to get working on things and forget to document things, but will try to keep track. Here's Red when we got her home on the trailer and tucked away in the back yard for the moment. Mike Attached image(s) |
mgarrison |
Mar 21 2021, 02:38 PM
I've been working along slowly. Just keep swimming... (IMG:style_emoticons/default/idea.gif)
I removed the tabs for the back pad. I don't have a back pad or 914 seats, and being six foot three will need all the room I can get! I see why there is not much paint or primer in the area under the head light buckets...HTH do you get in there??? I ordered this extension from Amazon, but it only takes a 1/8" shank, so very limited options other than Dremel ends. It kind of works, but not very well. I tried using it to get down in the corners of the fender well where it disappears behind the headlight bucket. The area under the headlight buckets had a bit of surface rust, but not bad. The "seam sealer" they used in this area was very different from the rest. It is dark and had hardened up to a brittle, charcoal like substance! Quite a bit chipped off rather easily: Here's a closeup of a big chunk, odd stuff: I moved over to the area under the gas tank. I needed to feel like I was making some progress/difference...needed to see some kind of change! (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 06:48 PM |
