| mgarrison |
Jan 14 2026, 01:56 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region
Thanks! Really appreciate the feedback...
I don't currently have any sway bars front or rear, but definitely something I need to keep in mind/plan for in the future! (IMG:style_emoticons/default/beerchug.gif) |
| mgarrison |
Jan 21 2026, 12:42 PM
I got started on my header modification. Definitely not my forte! Really feel like I'm floundering along with several do-overs already, and at least one more do-over I can already see coming...Ugh! (IMG:style_emoticons/default/headbang.gif)
I sliced up the header and got it ready to completely replace the first runner. I ordered this cutting template to help with the process. Seems ok, but not super... After fiddling around a bit I got the new runner at least tacked in place. A bit more slicing & splicing. |
| mgarrison |
Jan 21 2026, 12:45 PM
Test fitting what I've completed so far...
No real clue if I'm going to be able to fully finish weld all these joints, but I'll give it a shot for sure. Messing around with the "collector" (its pretty sketchy given what I paid for the headers, IMO). Trying to see where/how I can pull all three tubes back together and get the exhaust over the axle (IMG:style_emoticons/default/sawzall-smiley.gif) |
| Lilchopshop |
Jan 21 2026, 02:47 PM
Member ![]() ![]() Group: Members Posts: 116 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States |
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Glad to see you’re back at it! I really enjoyed making the exhaust for mine. |
| 76-914 |
Jan 21 2026, 08:36 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,964 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
These things are a game changer when fabricating an exhaust system.
| mgarrison |
Jan 22 2026, 06:28 PM
Yea, I got frustrated enough trying to hold tubes together I just ordered the clamps Chris showed in one of his Ferrari 914 videos. Not cheap, but they pivot to clamp bends too. (IMG:style_emoticons/default/beerchug.gif)
| mgarrison |
Jan 23 2026, 03:08 PM
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/popcorn[1].gif) Glad to see you’re back at it! I really enjoyed making the exhaust for mine. You're a better man than I am...I'm not exactly "enjoying" the header work! A bit too tedious and time consuming for the time I have available to work on it. Feels like I'm just getting going when it starts to get dark and I've got to button things up again for the night. |
| mgarrison |
Feb 16 2026, 04:40 PM
Well, I got the headers reassembled and pointing where I can use them...maybe. Really challenging trying to get in there for some of the welds - know I'll have some holes, but maybe good enough to at least test run the engine one day. (IMG:style_emoticons/default/confused24.gif)
| mgarrison |
Feb 16 2026, 04:46 PM
| mgarrison |
Feb 16 2026, 04:47 PM
More CAD design (IMG:style_emoticons/default/type.gif)
I still need to run the brake and clutch lines through here along with the wiring for engine sensors, etc. At least it's easily removable for modification, etc. |
| mgarrison |
Feb 16 2026, 04:48 PM
The blue stuff was just a cover that came on a bandsaw blade - thought I'd give it a quick try as a "seal" (IMG:style_emoticons/default/idea.gif) Split vacuum tube or something sure would look better! Figure I'll spray this black, or maybe even with Raptor liner so it hides it better. |
| mgarrison |
Feb 16 2026, 04:53 PM
I got the engine back in on Sunday. As my daughter says, I was on the struggle bus and it took way too long! (IMG:style_emoticons/default/headbang.gif) Got there eventually though.
Seems to be quite a bit of room for the rest of an exhaust system. I just need to find some mufflers that will fit the space on each side. |
| mgarrison |
Feb 16 2026, 05:01 PM
My neighbor walked over while the 914 was out front and we started discussing driveline angles. I cut a couple of lengths of PVC to mock up the axle angles and it sure looks like I should move the engine/trans as far to the rear as possible. It's currently pushed all the way forward. I have about 2" I can slide it back, but that means I will need to redo my trans mount!
I've been debating upgrading to a TIG welder...Given I still need to complete the rest of the exhaust, weld in a plate for the Tilton pedal cluster, and now redo the transmission mount, maybe it's better justified (or rationalized!) (IMG:style_emoticons/default/idea.gif) I would even be able to make the trans mount from stainless to match the stainless cradle... (IMG:style_emoticons/default/happy11.gif) Attached thumbnail(s) |
| 76-914 |
Feb 16 2026, 08:57 PM
My neighbor walked over while the 914 was out front and we started discussing driveline angles. I cut a couple of lengths of PVC to mock up the axle angles and it sure looks like I should move the engine/trans as far to the rear as possible. It's currently pushed all the way forward. I have about 2" I can slide it back, but that means I will need to redo my trans mount! I've been debating upgrading to a TIG welder...Given I still need to complete the rest of the exhaust, weld in a plate for the Tilton pedal cluster, and now redo the transmission mount, maybe it's better justified (or rationalized!) (IMG:style_emoticons/default/idea.gif) I would even be able to make the trans mount from stainless to match the stainless cradle... (IMG:style_emoticons/default/happy11.gif) Looking really nice Mike. You don't need TIG to do SS. Just use SS wire in your MIG. They recommend using a different gas but I've used std 25-75 with great results. IMHO, (go ahead and throw rocks at me Ben (IMG:style_emoticons/default/biggrin.gif) ) SS weld better than steel if you ask me. Keep up the GREAT work Mike. (IMG:style_emoticons/default/beerchug.gif) |
| mgarrison |
Feb 17 2026, 12:43 PM
My neighbor walked over while the 914 was out front and we started discussing driveline angles. I cut a couple of lengths of PVC to mock up the axle angles and it sure looks like I should move the engine/trans as far to the rear as possible. It's currently pushed all the way forward. I have about 2" I can slide it back, but that means I will need to redo my trans mount! I've been debating upgrading to a TIG welder...Given I still need to complete the rest of the exhaust, weld in a plate for the Tilton pedal cluster, and now redo the transmission mount, maybe it's better justified (or rationalized!) (IMG:style_emoticons/default/idea.gif) I would even be able to make the trans mount from stainless to match the stainless cradle... (IMG:style_emoticons/default/happy11.gif) Looking really nice Mike. You don't need TIG to do SS. Just use SS wire in your MIG. They recommend using a different gas but I've used std 25-75 with great results. IMHO, (go ahead and throw rocks at me Ben (IMG:style_emoticons/default/biggrin.gif) ) SS weld better than steel if you ask me. Keep up the GREAT work Mike. (IMG:style_emoticons/default/beerchug.gif) I only have a little HF flux core welder, no MIG. But, I did just order a new TIG setup so hopefully my welds will improve in the future and I can finally weld aluminum stuff too (assuming I have the required skills!) (IMG:style_emoticons/default/welder.gif) |
| mgarrison |
Feb 17 2026, 01:13 PM
I did receive my Outfront Motorsports headers. I briefly tried to test fit them and as is typical they need to occupy the exact same space as the crossbar for the engine cradle. You know the part that holds the motor mounts for the engine! (IMG:style_emoticons/default/headbang.gif) Now I need to pull the engine and trans out and start to ponder what solution might be the best option. Because the support angles forward it gives me much less room than I need (cradle is a knock-off of the early Coldwater cradle). I tried emailing Ian at Coldwater again to see if he has any of his new revision of the cradle that accommodates the Outfront headers, but no response now to several emails...wondering if Ian has stopped his side hustle for good...? I'll plan on posting some pics of my current challenge once I have the engine and trans back out. One step forward, two steps back. I was never any good at that "two-step" dancing thing! (IMG:style_emoticons/default/popcorn[1].gif) Even though I have the EG33, I had to cut my Outfront Motorsports headers not far from the cojoined 3 pipes and I used pre bent pipes to finish off my pipe routes. I'm not familiar with the bushings you use on the mounting points of the cradle...what is the purpose of those? I mounted my cradle directly to the front and rear mounting points, thinking that it strengthens the rear of the car and the stock Subaru mounts isolate the vibrations of the engine. It seems that they may not be needed and could give you more ground clearance as well. Not 100% sure, honestly. I've seen a bit of everything done by various folks here. Some use stock rubber mounts. Some hard mount. Some use Subaru transmission mount and some hard mount the transmission to the cradle. Not sure there's any real consensus on the best method. I was trying to land in the middle somewhere. Ground clearance seems ok from what I see...unless I have to run the headers UNDER the cradle. That would make things too tight I think and seems like a bad idea. I need to take some more measurements, etc. Really wondering if there's room for ANY kind of header given where the cross support lands right under the exhaust heads. Thought about exchanging the Outfront headers I have for the ones that go forward towards the front and then using a U pipe to bring them back to the rear. Not sure what will fit (IMG:style_emoticons/default/popcorn[1].gif) Mike, do as Michael suggests. Hard mount the cradle to the body and use the factory mounts. It strengthens the body. Re: transmission studs. As long as they terminate ~5.5" above ground your good. The factory plastic air flaps are ~5.5" above ground (on my 914) so I figured anything at or above 5.5" is as safe as the floor pan in the cabin. I also made it a point to have the oil pan clear that dimension also. IIRC, someone just modified an OutFront header to clear but I forget the process. It might have been posted on our FB Group. (IMG:style_emoticons/default/beerchug.gif) So, I tried several things when I put the engine back in on Sunday, but I quickly realized the transmission is as close to the underside of the trunk as possible already - that 3/4" bushing between the cradle and the transmission mount plates is needed. I did order some steel spacers to replace the urethane bushings that will allow me to use M12 bolts instead of the current M10s. Once those arrive I can work out removing the upper bushings above the mounts and figure out the correct length for the new M12 bolts. My ride height is not set yet since I just have scrap roller tires on there, but the lowest point on the oil pan is 6" above the ground. The cradle is 7-1/4" above ground, and the trans mount bolts are around 8" above ground. All seem manageable... |
| Chris914n6 |
Feb 17 2026, 02:11 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
V8 swaps move the trans back 1.25" with spacer blocks. For my V6 I used the same block to move it forward 1.25". There is flexibility in mounting, measure the max angle in 3d, not just horizontal or vertical.
| mgarrison |
Feb 23 2026, 12:09 PM
Here are the metal spacers I was able to find to replace the urethane bushings to create more of a "hard mount". Also went up from a M10 to M12 bolts for the mounts.
With those 3/4" spacers, here is the space I have left above the Subaru 5MT. I did upgrade from my little HF flux-core welder to an entry level AC/DC TIG welder. Now all I have to do is learn to TIG weld - no pressure at all! (IMG:style_emoticons/default/welder.gif) |
| jd74914 |
Feb 23 2026, 12:31 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,889 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I did upgrade from my little HF flux-core welder to an entry level AC/DC TIG welder. Now all I have to do is learn to TIG weld - no pressure at all! (IMG:style_emoticons/default/welder.gif) Nice! Have to say, I thought that Prime Weld machine worked as well as the Dynasty at school or HTP in the race shop. Really great machine for the money, it certainly won't be your limiter! (IMG:style_emoticons/default/smile.gif) |
| mgarrison |
Jul 15 2026, 06:27 PM
I swear I'm trying to work on the 914! In my addled brain I hear Yoda chastising me "Do or do not. There is no try." Life really seems to be conspiring to keep me from the 914!
Our son got married and moved to NM and he asked me to haul his toolboxes to the dealership in NM. A bit out of my comfort zone to put it mildly, but we got them there safe & sound. Gotta say backing this setup into a one car wide driveway at his in-laws house had me sweating big time - managed to tuck it in there without hitting anything, thank God! I will say don't buy a Jeep unless it's and older one with the 4.0L straight six! My wife's Wrangler JL blew the head gasket at 73k! And it's been maintained diligently. The shop actually suggested replacing the entire engine they have seen so many issues with the Pentastar V6! $6,300 to replace head gaskets, water pump, timing chain tensioners, etc. while it was apart... (IMG:style_emoticons/default/WTF.gif) If that wasn't enough, in the you just can't make this (IMG:style_emoticons/default/stromberg.gif) up category, my father in law pissed away over $600K in an online romance scam. Dude is so delusional he still doesn't believe his family, the police, or even the FBI that she isn't a real person and he isn't getting his money back! So, now we have the unbelievable joy of paying to move them down here and get them into an assisted living place where we can manage them effectively. I'm not bitter at all (IMG:style_emoticons/default/hissyfit.gif) When our son moved I was able to finally get the 914 and most of the parts into the garage. I'm still working on finishing up the exhaust, so I have it up on the Quick Jack which takes up a bit more space, but is still manageable. To try and provide some motivation - a tall order in PHX in July when the "low" is 88 degrees & 50% humidity, I mounted the engine cover on my garage wall. Given it was just a rattle can paint job to test the Ravena Green color, it doesn't look great. I remembered I had another engine cover with the Porsche lettering in the storage, so I pulled it out to see if I could buff it up and mount it to the wall instead. Was a bit more of a project than expected but has a decent "patina" to it! |
Lo-Fi Version | Time is now: 18th September 2026 - 01:38 AM |
