How hard is it to put a 2.4L -6 engine in? |
andreic |
Mar 1 2020, 12:28 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
I have the option of buying a 2.4L running engine from a 911T (F-model). The engine, with the carbs, is offered for $3900. First off, assuming I find nothing more about the engine, is this a reasonable price? (I asked already for compression, leak-down numbers, etc, I am waiting to hear the answers.) Second, how hard is it to get this engine installed in my 1.7L 914 (is it even possible?) and is this an enormous project that will take my car out of commission for several years, or is this more like a month-long project? In a different 914 I did do a full engine rebuild (1.8L), how does converting to a -6 compare in terms of complexity of the project? Thanks, Andrei. |
914Sixer |
Mar 1 2020, 12:45 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Go to the Classic section and read up one it. Pelican Parts has a how to also. George at AA has a booklet he published.
Mar 1 2020, 12:55 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Engine tin
Engine wire harness Engine bulkhead mount Clutch flywheel Oil tank Oil lines Headers or heat exchangers Muffler Modify oil cooler Modify tach Modify shift rod Oil pressure temp gauge Figure $10-15k to do it right. Read a bunch of conversion threads on this site. It’s all been done many times before. It’s always cheaper and faster to buy one already done but the project is part of the fun. Ben / MB911 owns 914-6Werkshop.com in Burlington WI. He can help you with parts or do the conversion for you. |
914forme |
Mar 1 2020, 12:56 PM
Wow what an open question. To some it will be the hardest thing they have ever done. To others it will be a walk in the park on a perfect day.
Some can do the swap in a weekend other will find it decades in doing. But the car was built around excepting both the type-4 and the 911 based -6. Both fit very well documented swap and books have been written about it. Enjoy the research, engine price, unless it is pure junk, or scam, is a great deal. |
Superhawk996 |
Mar 1 2020, 01:06 PM
914 Guru Group: Members Posts: 5,782 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Ben / MB911 owns 914-6Werkshop.com in Burlington WI. He can help you with parts or do the conversion for you. (IMG:style_emoticons/default/agree.gif) especially since OP is in WI. Also aregree on Mark's assessment of cost. /6 conversions aren't cheap but you won't regret the sound, low CG, and relative ease of a proper air cooled six swap. |
mlindner |
Mar 1 2020, 01:16 PM
Senior Member Group: Members Posts: 1,518 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Hi Andrei, all the comments are spot on with additional cost for five bolt 911 sespension, rust repair. My project is nearing the end if you would like to see. I'm just north of Madison (Merrimac) about 40 miles. On vacation in Florida for two more weeks then home. Best, Mark
horizontally-opposed |
Mar 1 2020, 01:30 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Ben / MB911 owns 914-6Werkshop.com in Burlington WI. He can help you with parts or do the conversion for you. (IMG:style_emoticons/default/agree.gif) especially since OP is in WI. Also aregree on Mark's assessment of cost. /6 conversions aren't cheap but you won't regret the sound, low CG, and relative ease of a proper air cooled six swap. (IMG:style_emoticons/default/agree.gif) A small six transforms the 914 experience—the car immediately feels different...hard to describe in some ways but mine went from feeling like an affordable sports car of the 1970s in the vein of a 2000s MR-2 Spyder to something altogether more expensive and even a hair exotic. Which is funny, because nearly everything else remains the same and I don't view 911 street engines as "exotic." But there is something about Porsche's air-cooled flat six in the lightest road car chassis ever designed to house it. I do miss a bit of the four-cylinder setup's lightness and "flickability," but I suspect I can improve the handling. My 2.2 conversion took years in terms of parts gathering, timing, etc, but went pretty quickly once it was started mainly because the person I worked with had converted a dozen or so 914-4s. It is an "easy" job for someone who knows what they're doing, since the 914 was designed by Porsche to accept a 911 engine, with maybe the "trickiest" part being the quality for the wiring conversion and cable linkages. My car has had precisely zero problems in the 8-9 years since the conversion. 2.4 is a great choice, whether mild and torquey as a T or wilder as a high-compression S. Ditto for 2.2, and while I know a lot of people love big sixes, I even like the 2.0 in the 914...mainly for the noises. Agree on the assessments on cost—$10-15k to do it right in addition to the engine, five-lug conversion (suspension/brakes/wheels). Some have done it on a real shoestring with great results (search for Trekkor...I seem to remember his DIY and very crafty conversion was $5k~ though that was a long time ago), while I suspect for others it can be a $50,000+ proposition if they're only writing checks for the conversion, a flat six build, and five-lug conversion. My advice, in either scenario: Work with people who have done multiple conversions if you can...and you are in the right place for that. |
porschetub |
Mar 1 2020, 01:44 PM
Sounds like a cheap engine priced as a core motor or a total steal ?,unless a European spec engine it has most likely been converted to carbs,all US motors were mechanical fuel injection and the last motors were CIS for one MY only.
This is a fairly involved conversion but there is a great network of parts to complete this as most original parts are NLA. The key point is the cost which isn't cheap by any means,go ahead and read the Pelican tech article but don't think the parts prices have been updated so everything will sound reasonably cheap which they are not these days. I purchased a mostly complete conversion and bought up the other parts needed over about one year,the motor was not with the car because I already had a 71 911 engine. There is a huge amount of info on this forum and many members have done conversions....read on, (IMG:style_emoticons/default/beer.gif) |
worn |
Mar 1 2020, 05:52 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hello, I have the option of buying a 2.4L running engine from a 911T (F-model). The engine, with the carbs, is offered for $3900. First off, assuming I find nothing more about the engine, is this a reasonable price? (I asked already for compression, leak-down numbers, etc, I am waiting to hear the answers.) Second, how hard is it to get this engine installed in my 1.7L 914 (is it even possible?) and is this an enormous project that will take my car out of commission for several years, or is this more like a month-long project? In a different 914 I did do a full engine rebuild (1.8L), how does converting to a -6 compare in terms of complexity of the project? Thanks, Andrei. I am in Madison and have a 3.2. I bought the motor first and then a car to go with, but the order doesn’t matter. I suggest that you read and read and read. Also, buy a suspension to go with your motor. You need to be able to slow down, if only to add gasoline. The 911 brakes go with a 5 lug conversion. Again, this and other websites are your friends. Let me know if you need some parts. My favorite drive is certainly the 914 with a six. Makes me wonder why they kept making new model cars. Oh of course. So my car can talk to me. |
porschetub |
Mar 2 2020, 01:21 AM
Ben / MB911 owns 914-6Werkshop.com in Burlington WI. He can help you with parts or do the conversion for you. (IMG:style_emoticons/default/agree.gif) especially since OP is in WI. Also aregree on Mark's assessment of cost. /6 conversions aren't cheap but you won't regret the sound, low CG, and relative ease of a proper air cooled six swap. (IMG:style_emoticons/default/agree.gif) A small six transforms the 914 experience—the car immediately feels different...hard to describe in some ways but mine went from feeling like an affordable sports car of the 1970s in the vein of a 2000s MR-2 Spyder to something altogether more expensive and even a hair exotic. Which is funny, because nearly everything else remains the same. There's just something about Porsche's OCH flat six when mounted in the lightest platform ever designed to house it. I do miss a bit of the four-cylinder setup's lightness and "flickability," but I suspect I can improve the handling. My 2.2 conversion took years in terms of parts gathering, timing, etc, but went pretty quickly once it was started mainly because the person I worked with had converted a dozen or so 914-4s. It is an "easy" job for someone who knows what they're doing, since the 914 was designed by Porsche to accept a 911 engine, with maybe the "trickiest" part being the quality for the wiring conversion and cable linkages. My car has had precisely zero problems in the 8-9 years since the conversion. 2.4 is a great choice, whether mild and torquey as a T or wilder as a high-compression S. Ditto for 2.2, and while I know a lot of people love big sixes, I even like the 2.0 in the 914...mainly for the noises. Agree on the assessments on cost—$10-15k to do it right in addition to the engine, five-lug conversion (suspension/brakes/wheels). Some have done it on a real shoestring with great results (search for Trekkor...I seem to remember his DIY and very crafty conversion was $5k~ though that was a long time ago), while I suspect for others it can be a $50,000+ proposition if they're only writing checks for the conversion, a flat six build, and five-lug conversion. My advice, in either scenario: Work with people who have done multiple conversions if you can...and you are in the right place for that. (IMG:style_emoticons/default/agree.gif) excellent reply...better than mine (IMG:style_emoticons/default/biggrin.gif) ,what you have said sums up the best points of this conversion the 911 "6" is a gem of a motor big or small bore form and is well suited to the 914. The real "6"got caught up in marketing politics ,shame really considering the racing history of the factory GT cars. |
Mark Henry |
Mar 2 2020, 09:39 AM
It's not hard to put a /6 into a 914, it's the cost. If you have the bankroll you can have it installed by the spring.
Hunting for bargains, added at least 2-3 years to my conversion. |
morgan_harwell |
Mar 2 2020, 10:36 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
It's not hard to put a /6 into a 914, it's the cost. ^ "not hard" 33 years ago, I put a 911 2.4L-T into my 914. It was my 1st and only /6 conversion. I did all of the work. It took me about 3 months worth of weekends, which included re-painting the engine bay. It was not too hard or complicated, just time consuming. "it's the cost" In 1987 I spent $6,687.50 to buy the engine and get it running in the 914 (per my spread sheet). That is $15,230 in 2019 dollars. $2,765 was for the engine (1987 dollars). The $6687.50 does not include the 911 suspension & brake upgrades I did a couple of years later. Incidentally, that 2.4L /6 is still in my 914 today (IMG:style_emoticons/default/smile.gif) Great 914 touring motor. |
Bleyseng |
Mar 2 2020, 11:30 AM
I picked up a 911 2.4 for cheap in 2005ish. Looked at pricing installing it then and said forget it for 130hp. Sold it to Dan Root who installed in one of his 914/6 conversion projects. Now if the engine is a nice 3.2 complete with everything I would do it.
Root_Werks |
Mar 2 2020, 11:38 AM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I picked up a 911 2.4 for cheap in 2005ish. Looked at pricing installing it then and said forget it for 130hp. Sold it to Dan Root who installed in one of his 914/6 conversion projects. Now if the engine is a nice 3.2 complete with everything I would do it. I remember that, the 914 I put that engine in was nice. Signal Orange I believe. It had the stock steel wheels on it with hub caps. What a sleeper that was! 15 years ago you could do a six conversion for $5-7k depending on deals you could get. These days....seems about triple that. |
Mar 2 2020, 11:50 AM
It's not hard to put a /6 into a 914, it's the cost. If you have the bankroll you can have it installed by the spring. Hunting for bargains, added at least 2-3 years to my conversion. ^ My experience, also. I collected the stuff I had to supply (carbs, a tach, engine tins, engine mount, a muffler, an airbox, etc) over a couple of years before John Holleran started building the engine. He had a NOS oil tank, NOS lines, and everything else to build the engine up. Back then, he was between shops...so the work happened in three different places. If the engine had been ready to go, as is the case with the OP, it probably could have been done in a couple of weeks...and maybe less. I am sure there is a record out there... |
Mar 2 2020, 11:58 AM
I picked up a 911 2.4 for cheap in 2005ish. Looked at pricing installing it then and said forget it for 130hp. Sold it to Dan Root who installed in one of his 914/6 conversion projects. Now if the engine is a nice 3.2 complete with everything I would do it. ^ Yep, understandable. I might have done the same thing, and actually would have back in 2010. But the more I drive today's blindingly fast cars, the more I realize paper horses are a red herring. It's the experience, and the way an engine makes its power and a car can use that power, that make a car fun in the real world (see: 914-4 as an example even with 80hp...and 130hp is a 62% increase). A 2.4 911T is a really nice car to drive...so how much more so in a lighter 914 chassis? When I drive my 2.2, which is probably making 190~ hp, its output is only part of the equation. A lot of the fun in a six conversion is the noise, which is pure Le Mans 1970—or at least closely linked to it. Other nice thing about a six conversion is what it enables: Once you have a six in, the car is set up for all manner of sixes. Some will require an oil cooler, but that's about it... |
morgan_harwell |
Mar 2 2020, 01:03 PM
A lot of the fun in a six conversion is the noise, which is pure Le Mans 1970 I heard that !! Many years ago, when my son was about 4 years old, we watched the movie LeMans on our home theatre system. The next day we went somewhere in my 2.4L 914-6 conversion car. The 1st time I 'got on it' a little bit, my son exclaimed excitedly "Ooh, Race Car"! Decades later, I still smile thinking about that day. |
Bleyseng |
Mar 2 2020, 01:15 PM
I went the stealth stock 4 route using Raby parts to bump up the HP to 120HP with Djet FI and heat. With close ratio transmission its plenty fast and great to drive. The only thing missing is the 6 sound which is okay as the wife likes the car quiet. (IMG:style_emoticons/default/chair.gif)
Root_Werks |
Mar 2 2020, 01:21 PM
Yup, none of us here should fool ourselves thinking our 120, 180 or even 340hp 914's will be the quickest cars on the road these days. Think the new Tesla Roadster 0-6 in 1.9 seconds.
We drive 914's because we like them and they are a part of history. Heck, It's been almost 10 years since I owned one and I still came back. Coulda bought a used first Gen Tesla Roadster for the same money. I'd rather have a 914. |
ConeDodger |
Mar 2 2020, 01:24 PM
Apex killer! Group: Members Posts: 23,580 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Ben / MB911 owns 914-6Werkshop.com in Burlington WI. He can help you with parts or do the conversion for you. (IMG:style_emoticons/default/agree.gif) especially since OP is in WI. Also aregree on Mark's assessment of cost. /6 conversions aren't cheap but you won't regret the sound, low CG, and relative ease of a proper air cooled six swap. (IMG:style_emoticons/default/agree.gif) A small six transforms the 914 experience—the car immediately feels different...hard to describe in some ways but mine went from feeling like an affordable sports car of the 1970s in the vein of a 2000s MR-2 Spyder to something altogether more expensive and even a hair exotic. Which is funny, because nearly everything else remains the same and I don't view 911 street engines as "exotic." But there is something about Porsche's air-cooled flat six in the lightest road car chassis ever designed to house it. I do miss a bit of the four-cylinder setup's lightness and "flickability," but I suspect I can improve the handling. My 2.2 conversion took years in terms of parts gathering, timing, etc, but went pretty quickly once it was started mainly because the person I worked with had converted a dozen or so 914-4s. It is an "easy" job for someone who knows what they're doing, since the 914 was designed by Porsche to accept a 911 engine, with maybe the "trickiest" part being the quality for the wiring conversion and cable linkages. My car has had precisely zero problems in the 8-9 years since the conversion. 2.4 is a great choice, whether mild and torquey as a T or wilder as a high-compression S. Ditto for 2.2, and while I know a lot of people love big sixes, I even like the 2.0 in the 914...mainly for the noises. Agree on the assessments on cost—$10-15k to do it right in addition to the engine, five-lug conversion (suspension/brakes/wheels). Some have done it on a real shoestring with great results (search for Trekkor...I seem to remember his DIY and very crafty conversion was $5k~ though that was a long time ago), while I suspect for others it can be a $50,000+ proposition if they're only writing checks for the conversion, a flat six build, and five-lug conversion. My advice, in either scenario: Work with people who have done multiple conversions if you can...and you are in the right place for that. Pete’s car is a beautiful narrow body. Mine is a wide body with a 3.2 and fully developed suspension. I agree with pretty much everything Pete has said and would add, Patrick Motorsport’s in Arizona where you can easily spend $100K on a conversion. Ben and McMark at Original Customs are both good for conversions. McMark did most of mine, though I did contribute ideas and labor. I’d guess $15K when all done for mine not including flares and suspension? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 04:43 AM |
