Exhaust Nuts, I must be the one that is nuts! |
ctc911ctc |
Mar 2 2020, 08:38 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Took the exhaust system off of the car
------ '74, 2.0L all stock ------- to replace a stud (see my last post on the lost stud) I wanted to get new nuts to go with the new studs so i researched and bought brass nuts advertised by EMPI The ones I took off are steel with copper thread inserts, I have no experience with either, thoughts? |
yeahmag |
Mar 2 2020, 09:42 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I like the 11mm heads (on 8mm) nuts for exhaust and carb manifolds. I always use a bit of anti seize too.
jmitro |
Mar 2 2020, 10:32 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
ha. less than 2 minutes ago I placed an order for some exhaust manifold nuts/ studs/ time sert repair.
I used this thread for reference, and bought the ACN nuts linked in the thread http://www.914world.com/bbs2/index.php?act...=2&t=286730 |
IronHillRestorations |
Mar 3 2020, 08:26 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You want a flange nut. They are much stronger than a nut with a washer, as well as easier to use.
You do not want a prevailing torque (locking) fastener as they will make the exhaust studs back out. There are prevailing torque copper coated flange nuts that are used on other German cars (BMW I think) that often get sold for our cars. I've used these as well, after running a tap through them. |
VaccaRabite |
Mar 3 2020, 12:06 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Don't use the common copper colored "exhaust" nuts. Really hard on your head studs. Do use the thin profile 8mm nuts that can be found at Belmetric and McMaster Carr. If you can find them flanged thats even better. Zach |
porschetub |
Mar 3 2020, 01:01 PM
You want a flange nut. They are much stronger than a nut with a washer, as well as easier to use. You do not want a prevailing torque (locking) fastener as they will make the exhaust studs back out. There are prevailing torque copper coated flange nuts that are used on other German cars (BMW I think) that often get sold for our cars. I've used these as well, after running a tap through them. I used the BMW ones on my 6 motor and on a 4,found them very good and they don't come loose,bought them off Pelican and seem to remember they were cheap enough,good solution. |
Mar 3 2020, 01:38 PM
914-6 GT in waiting Group: Members Posts: 19,257 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
something like this works well.
ctc911ctc |
Mar 3 2020, 02:43 PM
Has anyone used nuts made of brass like the ones in the picture below????
Just curious, not trying to stir the pot! (IMG:style_emoticons/default/stirthepot.gif) Took the exhaust system off of the car ------ '74, 2.0L all stock ------- to replace a stud (see my last post on the lost stud) I wanted to get new nuts to go with the new studs so i researched and bought brass nuts advertised by EMPI The ones I took off are steel with copper thread inserts, I have no experience with either, thoughts? |
JamesM |
Mar 3 2020, 11:22 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I like the 11mm heads (on 8mm) nuts for exhaust and carb manifolds. I always use a bit of anti seize too. (IMG:style_emoticons/default/agree.gif) but i like these 8x10 flanged nuts even better! http://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm Really handy to keep your socket from wedging against your exhaust when tightening, especially with headers. Added bonus, the flange keeps the nut from sliding down in your socket before you get it on the stud. I never thought I would get so excited over a nut but I LOVE these things |
rhodyguy |
Mar 4 2020, 09:24 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
NICE! I'm going to get sets for the HEs and intakes. Thanks.
anderssj |
Mar 4 2020, 09:37 AM
Dog is my copilot... Group: Members Posts: 1,655 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Used the 8x10 flange nuts from air-cooled net when reinstalling my HEs a couple of months ago. REALLY nice pieces.
StarBear |
Mar 4 2020, 03:54 PM
Senior Member Group: Members Posts: 1,862 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
This forum is tops - such experience even for a set of nuts! Best source of info.
ctc911ctc |
Mar 5 2020, 03:32 PM
It's not the nuts, it's the Nuts talking about nuts!
(IMG:style_emoticons/default/party.gif) This forum is tops - such experience even for a set of nuts! Best source of info. |
Lo-Fi Version | Time is now: 8th May 2024 - 03:20 PM |
