Newbie Weber question |
Tdskip |
Mar 5 2020, 01:01 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Root_Werks |
Mar 5 2020, 01:09 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Do you have screws or the rivets on the butterflies? To me, the screws make it easier.
Either way, it's not a small task. It's hard to remove the screws or rivets without damaging something. That's probably mostly because I don't have the proper tools. (IMG:style_emoticons/default/dry.gif) |
Tdskip |
Mar 5 2020, 01:31 PM
Thanks for the confirmation, appreciate the coaching.
Root_Werks |
Mar 5 2020, 01:57 PM
And if you want to dump those 40's, I have a set of P11-4's bored to 44's with matching manifolds for a 356/912 engine. (IMG:style_emoticons/default/biggrin.gif)
Tdskip |
Mar 5 2020, 02:28 PM
I have a spare set of 40s and a set of Dels, but I’ll probably mess those all up so I’ll let you know!
Thanks again |
rgalla9146 |
Mar 5 2020, 03:34 PM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The spring is positioned incorrectly on that carb
Tbrown4x4 |
Mar 6 2020, 05:57 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Messing with the throttle plates is fiddly. The progression holes are drilled after the plates are installed, so changing anything around can mess up their relationship. Better to have Pierce Manifolds go through them or maybe @ThePaintedMan .
If the relationship between the progression holes and the plates is wrong, you'll have a hard time tuning the carbs. Also, isn't there a small nut deep in the end of that extension? |
Tdskip |
Mar 6 2020, 06:46 AM
Thanks for the responses.
Thanks for the eyes on the spring, how it came to me. @TBrown4x4 - Another member here also suggested removing a nut in that shaft opening. There isn’t on in there. Looks like Allen head fitting and you cannot rotate the shaft because it will hit the idle screw housing. Pretty sure the whole shaft needs to come out (on this one anyway). |
Tbrown4x4 |
Mar 6 2020, 07:48 AM
It makes sense that there isn't enough room for a regular nut. Probably a barrel nut. Put an Allen head down there and hold the shaft. You might also turn in the idle screw so the throttle plates are not touching the carb throats, and turn the Allen wrench against that.
Tdskip |
Mar 6 2020, 02:39 PM
It makes sense that there isn't enough room for a regular nut. Probably a barrel nut. Put an Allen head down there and hold the shaft. You might also turn in the idle screw so the throttle plates are not touching the carb throats, and turn the Allen wrench against that. Thanks for the follow up. I don’t see a way for the shaft to separate, I asked for some help over at the 912 forum and one member over there said the shafts are one piece. |
Tdskip |
Mar 6 2020, 03:56 PM
Checked again and just can't see a way to rotate the shaft loose as pictured - it must have the long extension assembled and then the narrow (other) side passed through.
So good for a 914, so not going to mess with it, but bad for a 912. |
Tdskip |
Mar 6 2020, 10:08 PM
@Tbrown4x4 - you were right.
I came back to this after re-reading your posts and it clicked. Shaft extension off, easy. Thanks again and sorry it didn’t click. |
rhodyguy |
Mar 7 2020, 07:54 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Nice catch Todd.
Tdskip |
Mar 7 2020, 08:10 AM
Tbrown4x4 |
Mar 7 2020, 03:17 PM
Glad it worked out. Happy to help.
Tdskip |
Mar 7 2020, 03:24 PM
Also realized, as was pointed out, the DPO wasn't using the correct spring set up so I fixed that as well and they now snap shut as they should.
Thanks! |
Lo-Fi Version | Time is now: 8th May 2024 - 09:43 AM |
