Metal Fuel Lines, Vendor for Metal Fuel Lines |
xsurfer |
Mar 7 2020, 04:06 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I need to purchase metal fuel lines to bend myself for a stock 914-6. Anyone know
a vendor or shop that sells the correct sizes? Thanks Gene |
mepstein |
Mar 7 2020, 04:13 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Tangerine Racing. Call Chris if you have any questions. He knows our cars better than most. (IMG:style_emoticons/default/beerchug.gif)
http://www.tangerineracing.com/stainlessfuellines.htm @xsurfer |
Coondog |
Mar 7 2020, 11:12 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
What ever happened to Rotary14, he lives next to Dodger stadium. He use to sell them at Bruce’s swap meet. Bought mine from him.
bbrock |
Mar 7 2020, 11:14 PM
76-914 |
Mar 8 2020, 09:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
They both make great SS fuel lines. I think it depends upon which coast you live on. To answer the OP's question: I don't know where to source metric SS line. I know the speed shops stock SAE size lines. (IMG:style_emoticons/default/beerchug.gif)
bbrock |
Mar 8 2020, 09:45 AM
I think he is looking for mild steel lines which, like you said, are available at your FLAPS. There is a good article on Pelican on making them from SAE sized lines. I was going to do that but by the time I figured in the tooling for bending and creating bubble fittings on the ends, I was approaching the cost of pre-made lines from @Rotary'14 . Plus, I was able to source all the other bits needed at the same time.
Rotary'14 |
Mar 8 2020, 01:51 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I'm here if xsurfer wants to drive down the 2 freeway and pick them up.
-Robert |
porschetub |
Mar 8 2020, 02:11 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I think he is looking for mild steel lines which, like you said, are available at your FLAPS. There is a good article on Pelican on making them from SAE sized lines. I was going to do that but by the time I figured in the tooling for bending and creating bubble fittings on the ends, I was approaching the cost of pre-made lines from @Rotary'14 . Plus, I was able to source all the other bits needed at the same time. I used truck brake line pipe,bends easily and won't corrode,I happened to have the correct bender in my toolbox. You could use a brake line flaring tool to partially make a flare,I didn't do this as I'am running carbs on low pressure. |
80’s old school |
Mar 8 2020, 11:12 PM
Member Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California |
I need to purchase metal fuel lines to bend myself for a stock 914-6. Anyone know a vendor or shop that sells the correct sizes? Thanks Gene I bent mine myself. Went to Grainger to get the stainless tubing. They sell a bunch of different versions of stainless tubing so I went to the Grainger in Rancho Cucamonga and worked with the counter guy to get what I needed. |
Mikey914 |
Mar 8 2020, 11:18 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We Make the rubber "stopper" grommet (on the engine firewall)you may need both 8 and 10 mm
https://900designs-container.zoeysite.com/s...ch/?q=fuel+line Attached thumbnail(s) |
xsurfer |
Mar 10 2020, 09:11 AM
dr914@autoatlanta.com |
Mar 10 2020, 09:23 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
76-914 |
Mar 10 2020, 09:54 AM
I'm here if xsurfer wants to drive down the 2 freeway and pick them up. -Robert Do you have the fuel lines bent or straight pipe. Either way I'm interested. I'm Gene @ 818 9575791 Hope to speak with you soon. Thanks They're pre-bent and he has a video showing the install. It can be done by one person but is easier with 2. He also sells the gaskets and screened filter that fit at the base of the fuel tank. You'll be pulling the tank so replace these bits when replacing the lines. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 02:04 AM |
