Mystery, Bolts? |
Mystery, Bolts? |
shane |
Mar 8 2020, 07:11 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
jmitro |
Mar 8 2020, 07:17 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
valve adjusters?
KevinW |
Mar 8 2020, 07:21 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
Headlight adjusters
bkrantz |
Mar 8 2020, 07:36 PM
914 Guru Group: Members Posts: 7,754 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
shane |
Mar 8 2020, 07:38 PM
Hi thanks, theses are M8 bolts where on the headlights would they go? Thanks
KevinW |
Mar 8 2020, 07:54 PM
They mount on the bucket to adjust the amount of travel. It is a stop adjustment.
shane |
Mar 8 2020, 07:57 PM
KevinW |
Mar 8 2020, 08:02 PM
You can see the bolts they are brown in the picture right below the gray tube
Attached thumbnail(s) |
914_7T3 |
Mar 8 2020, 08:03 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,848 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
rgalla9146 |
Mar 8 2020, 08:24 PM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
They act as stops in the 'fully raised' position to prevent vibration of the headlight.
Mar 8 2020, 10:07 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They mount on the bucket to adjust the amount of travel. It is a stop adjustment. No, please don't use them as a "stop" to adjust travel! The bolts are only supposed to just barely touch the tabs on the headlight bucket when the headlights are in the fully open position to prevent the light from vibrating when open. If you remove those bolts you'll see that the headlights will still stop just fine in the open position, there is no "stop" needed at all. (IMG:style_emoticons/default/shades.gif) |
lierofox |
Mar 9 2020, 03:12 AM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
They mount on the bucket to adjust the amount of travel. It is a stop adjustment. No, please don't use them as a "stop" to adjust travel! The bolts are only supposed to just barely touch the tabs on the headlight bucket when the headlights are in the fully open position to prevent the light from vibrating when open. If you remove those bolts you'll see that the headlights will still stop just fine in the open position, there is no "stop" needed at all. (IMG:style_emoticons/default/shades.gif) Almost sounds like something you'd send a newbie out to grab. Grab me a pack of piston return springs. Need a tube of elbow grease. Go in and ask for a headlight antivibe bolt. |
ClayPerrine |
Mar 9 2020, 06:48 AM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
ctc911ctc |
Mar 9 2020, 09:40 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Of all of the parts in my '74 2.0 these bolts were (are) the most rusted, where might I find a pair of these for sale?
914 RZ-1 |
Mar 9 2020, 02:21 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Of all of the parts in my '74 2.0 these bolts were (are) the most rusted, where might I find a pair of these for sale? Can you remove them? If so (PB Blaster might help), I'd recommend soaking them in Evaporust before trying to get new ones. You can also take a wire wheel to them to get the crud off. |
ctc911ctc |
Mar 9 2020, 08:05 PM
There is not enough to save - seriously, they are toast! Looked for a picture (where is that thing, I know I took one) - will take one and post - kinda funny how little is left.
Lo-Fi Version | Time is now: 9th May 2024 - 08:30 AM |
