Help wiring fuel pump, fuel injection to carbs |
n2j2ryan |
Mar 10 2020, 11:07 PM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
I have a 72 which had a 1.7 wired for fuel pump with injectors. I now have a 2.0 with carbs and a new fuel pump from tangerine. I have been reading the other posts, but am not a great mechanic so I want to just make sure of a couple of things.
1. From what I understand the wire currently running to the fuel pump will not work as it is constantly hot? 2. What is the best way to bring power to the fuel pump? 3. What should I do with the hot wire? Could I use that to run my heated seats? (sorry, I am really not too keen on electrical). Is this something I should be hiring someone with a bit more knowledge to complete? Thanks for all of your help. Getting really close to having a running car after 3 years! |
n2j2ryan |
Mar 10 2020, 11:31 PM
Just after posting I found Andy's article which seems to answer all my questions...
Could still use some help figuring out how to bring power to the heated seats though! |
HansJan |
Mar 10 2020, 11:45 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
porschetub |
Mar 10 2020, 11:55 PM
Just after posting I found Andy's article which seems to answer all my questions... Could still use some help figuring out how to bring power to the heated seats though! Excellent,so much info on here,make sure have the right pump,the CB Performance/Carter rotary is the best option which makes 3.5PSI which is fine but I found mine made more than that so I had already fitted a low pressure Holley fuel regulator and dropped my pressure to 3.0 + PSI and no issues. Make sure your original fuel and voltage control relays are good and you will be golden,please use quality fuel line and FI hose clamps so we don't see a burnt car on here...sounds tough but fairly common with a 914. Good Luck. |
GregAmy |
Mar 11 2020, 06:54 AM
Advanced Member Group: Members Posts: 2,297 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Could still use some help figuring out how to bring power to the heated seats though! I believe that the seat heaters can be powered from the same source as the backup sensors. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/av-943.gif) |
n2j2ryan |
Mar 11 2020, 10:15 AM
Just after posting I found Andy's article which seems to answer all my questions... Could still use some help figuring out how to bring power to the heated seats though! Excellent,so much info on here,make sure have the right pump,the CB Performance/Carter rotary is the best option which makes 3.5PSI which is fine but I found mine made more than that so I had already fitted a low pressure Holley fuel regulator and dropped my pressure to 3.0 + PSI and no issues. Make sure your original fuel and voltage control relays are good and you will be golden,please use quality fuel line and FI hose clamps so we don't see a burnt car on here...sounds tough but fairly common with a 914. Good Luck. Great info and help. I did purchase the stainless fuel lines as well so I am assuming those are good quality. Thanks |
n2j2ryan |
Mar 11 2020, 10:21 AM
Just after posting I found Andy's article which seems to answer all my questions... Could still use some help figuring out how to bring power to the heated seats though! I believe that the seat heaters can be powered from the same source as the backup sensors. Thanks. That was very helpful! Unfortunately my back up sensors are already hooked up with the power windows and sunroof so I will have to find another source. |
bdstone914 |
Mar 12 2020, 05:39 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@n2j2ryan :
' date='Mar 11 2020, 09:21 AM' post='2793198'] [quote name='HansJan' post='2793085' date='Mar 10 2020, 10:45 PM'] [quote name='n2j2ryan' post='2793084' date='Mar 11 2020, 12:31 AM'] Just after posting I found Andy's article which seems to answer all my questions... Could still use some help figuring out how to bring power to the heated seats though! [/quote] I believe that the seat heaters can be powered from the same source as the backup sensors. [/quote] Thanks. That was very helpful! Unfortunately my back up sensors are already hooked up with the power windows and sunroof so I will have to find another source. [/quote] How much power do the seat heaters pull? I would be concerned that the circuit that you use can safely carry the load. Bruce |
n2j2ryan |
Mar 14 2020, 08:18 PM
[quote name='bdstone914' date='Mar 12 2020, 04:39 AM' post='2793407']
@n2j2ryan : ' date='Mar 11 2020, 09:21 AM' post='2793198'] [quote name='HansJan' post='2793085' date='Mar 10 2020, 10:45 PM'] [quote name='n2j2ryan' post='2793084' date='Mar 11 2020, 12:31 AM'] Just after posting I found Andy's article which seems to answer all my questions... Could still use some help figuring out how to bring power to the heated seats though! [/quote] I believe that the seat heaters can be powered from the same source as the backup sensors. [/quote] Thanks. That was very helpful! Unfortunately my back up sensors are already hooked up with the power windows and sunroof so I will have to find another source. [/quote] How much power do the seat heaters pull? I would be concerned that the circuit that you use can safely carry the load. Bruce Thanks Bruce That is something that I will have to check out. I know quite a few guys up here have them so it is definitely doable. I think I will wait until I get the rest of the gremlins sorted out before I tackle them. [/quote] |
Lo-Fi Version | Time is now: 14th May 2024 - 06:59 AM |
