1974 black interior back pad |
brant |
Mar 11 2020, 09:04 AM
so this has some damage
primarily.... you will see on the drivers section, I drilled holes through the back pad to install racing seat belts additionally there is some of the normal cracking and damage at the bottom (for example, there is a hole drilled on the passenger side third, bottom... where I used to run a heavy battery cable through the drilled hole. so there is some damage the foam is good some of the cardboard is good most of the material is good except for the seat belt mounting holes primarily I can take more pictures and answer questions I've never shipped one of these it looks like the ideal way would be to take it apart into 3 sections the box is still going to be pretty big with 3 sections on top of each other how about $50 + actual shipping fee's (and I'm just guessing, but slightly over sized so shipping could run up to 30?) brant Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 AM |
