so this has some damage
primarily.... you will see on the drivers section, I drilled holes through the back pad to install racing seat belts
additionally there is some of the normal cracking and damage at the bottom
(for example, there is a hole drilled on the passenger side third, bottom... where I used to run a heavy battery cable through the drilled hole.
so there is some damage
the foam is good
some of the cardboard is good
most of the material is good except for the seat belt mounting holes primarily
I can take more pictures and answer questions
I've never shipped one of these
it looks like the ideal way would be to take it apart into 3 sections
the box is still going to be pretty big with 3 sections on top of each other
how about $50 + actual shipping fee's
(and I'm just guessing, but slightly over sized so shipping could run up to 30?)
brant
